rerod
Iowa
Iv never dumped back or gray, or even used them. Total newbie Here is what I have..
My hose looks like its only half of what I need. I have a camping-world merchandise certificate burning a hole in my wallet.. What should I buy?
1995 E350 6bt/nv4500, 2006 Featherlite 24' surv toyhauler, 2007 DRZ400s well farkled, 1985 Vmax stock, 1985 Vmax custom
hallock5
At minimum, the end of your hose should have a collar with cleats on it which serves two-folds: 1) can attach elbow that you will need at most parks at the park's sewer tap 2) can attach 2nd hose to your first to extend your reach.
Something like this.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
jls
canastota, ny
It appears you have all you need. The end of the hose to the left as pictured goes on the dump fitting. It goes on then turns to the right to hold. The right end (as pictured) goes in the hole at the dump station. You then open the Black first(usually the larger valve)then when black is done draining, open the gray. That way the gray rinses the hose.
john and Pam
2006 Chev K1500 Z71 4x4 5.3L
2002 Sunline Solaris T-2553
#24 TO THE FRONT
tenbear
Northern Vermont, USA
You may be able to get by with what you have but it looks as if your hose is to short and there is no sewer fitting on one end.
Here is what you need. It has 20' of hose and a sewer connector. You may also need a sewer doughnut at some campgrounds to seal the connection.
Enjoy camping.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
PikeRoadWarrior
Pike Road, Alabama
You've got all you need. If you want something a little bit fancier, you can purchase this little gem.
2004.5 Dodge 2500 Cummins 4x4
2009 Sabre 31BHDS
lanerd
Newport, OR
good advice above. Would like to add that a clear connection that goes between your tank's gate and the hose will really come in handy to let you know what is coming out and when it is finished.
Clear Connector
Another item that is also handy (that is if your tank doesn't already have one) is this: Quickie Flush
good luck
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
skipnchar
Topeka or somewhere else
Just for your consideration and clarification: No RV has a septic system so don't confuse that with the holding tanks on the RV. They are entirely different and require different care and treatment.
Good luck / Skip
Robby9
Oklahoma City
Two hoses are frequently needed at full hookup sites. Also, an elbow will be needed. Most newer sites have threaded pipes for the dump, eliminating the need for a donut.
Flush King or a quikie flush is real nice to have.
enblethen
Moses Lake, WA
I switched out to this system. Much easier to store.
Rhino
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
SGardiner
Georgetown, Ontario
Not an expert on this topic, but this video may be helpful
Clean and Flush Black Tank
