RV.Net Open Roads Forum: Beginning RVing: Need septic system gear..
 > Need septic system gear..
Bipeflier
Centralia, MO
Posted: 07/23/12 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Just a heads up since you are new to RVing. If you park in a spot with sewer connection, DO NOT connect your hose and leave the dump valve on your black water tank OPEN. Leave the valve closed until your tank is at least 3/4 full, or until you are ready to leave and go home.
If you leave the valve open the liquid "stuff" will drain and the solid "stuff" will stay in the tank, harden, and be a bear to remove.
If you already knew this, I appologize for the redundency.
2010 Cruiser CF30SK Patriot
2011 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
pawatt
Brainerd MN / Mission TX
Posted: 07/23/12 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
This is a must & is worth repeating.
Recycled1
Marina del Rey, CA
enblethen wrote:
I switched out to this system. Much easier to store.
Rhino
2x. I recently stayed at a pvt campground where they come by and check if you have a right angle elbow, before they will unlock the sewer connection and let you connect.
Old-Biscuit
Across the USA
Posted: 07/23/12 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
This advice is golden....
Also after dumping your black and rinsing it. Close dump valve and then add couple of full toilet bowls of water back into black tank so bottom of tank stays wet and any 'stuff' left behind can just slosh around as you drive.
Then dump your grey water tank so the semi-clean & soapy water can rinse out drain line and sewer hose.
So you got one sewer hose...get an extra one
Get the clear adapter so you can see what/how it's draining & when done
Get the sewer line threaded adapter to screw into CG sewer line fitting and hook your hose up to
Get the spongy/rubber sewer 'donut' to stick inside CG sewer line if it's just a straight pipe then stick your threaded adapter thru it and hook up your hose
Get a tank rinser wand for rinsing thru toilet or install one into black tank if your trailer doesn't have one
Good luck.........and no 'Robin Williams' unless you post pictures
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
tenbear
Northern Vermont, USA
Posted: 07/23/12 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of good advice here. I have a couple of thoughts:
If you are planning to store the sewer hose in the 4" metal tube that runs across the back of many RVs, you will find that the Rhino will not fit in the tube.
2 hoses are better than one. Most of the time you will only need to use a short length, and it is easier to work with a 10' hose than a 20 footer.
IMHO the person in the video mentioned above gets carried away with getting his black tank clean. It isn't necessary to get it absolutely clean. You certainly don't want to go thru all that at the dump station with other RVers waiting in line.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
Here'n'There
Posted: 07/24/12 10:19am Link  |  Quote  |  Print  |  Notify Moderator
jls wrote:
It appears you have all you need. The end of the hose to the left as pictured goes on the dump fitting. It goes on then turns to the right to hold. The right end (as pictured) goes in the hole at the dump station. You then open the Black first(usually the larger valve)then when black is done draining, open the gray. That way the gray rinses the hose.
Hummmmm.... BEFORE following this advise, especially the part that says "The right end (as pictured) goes in the hole at the dump station" I would strongly suggest you beg, borrow, or steal (not really) the DVD movie "RV" and watch the Dump Station scene several times.
After that, you will be purchasing the proper connecting hardware for the dump stand pipe as offered by other responses.
Good Luck
Here'n'There
2009 Carri-Lite 36SBQ 5th Wheel
2008 Dodge Ram 3500 Quad Cab Long Bed Diesel Dually
On the road with Here'n'There
Role of the C133 in Viet Nam
DanKirk
NorCal
Posted: 07/24/12 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe not in some, but my Rhino hose fits in my 4" square bumper tube, including the 90 degree end.
2008 Wilderness 240RKS
2011 Dodge Ram 2500 4X4 Crew Cab Cummins Turbo Diesel
Turtle n Peeps
California
Posted: 07/24/12 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
You need a hose spreader.
outside the fire"
rerod
Iowa
Posted: 07/24/12 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the time saving suggestions.
Will the Rhino fit into my 4 1/4" ID tube seen on the front is this picture?
1995 E350 6bt/nv4500, 2006 Featherlite 24' surv toyhauler, 2007 DRZ400s well farkled, 1985 Vmax stock, 1985 Vmax custom
jalichty
Lander, Wyoming 82520
Posted: 07/25/12 07:17am Link  |  Quote  |  Print  |  Notify Moderator
The Rhino fits in my bumper in the back of my FW just fine. You just have to twist the connector a bit to get it in the proper position to slide in. Biggest problem I have is getting it back out, I have to put fingers around both sides of the dump "connection" side to grab it and slide it out, don't seem to be able to just grab it with one set of fingers. Might not be the connection's fault, maybe I'm just a little bit uncoordinated and fingers a little to fat.
John A. Lichty
