samsontdog
Oregon, Wash Coast summer, Yuma Az winter
I went from a 28 ft to a 34 ft TT and loved it . No problems getting in and out of Service Stations. I see no reason to spend big money on a high dollar hitch as my EZ Lift works great.I am looking at a 35 ft TT next week
samsontdog
OhhWell
We went from a 28' to a 34' as well. I do notice lateral push from the trailer when a truck passes me but that is to be expected. It was just more noticeable, not dangerous by any stretch. I haven't yet taken a trip where I need to gas up with the trailer on the truck. I had trouble at some poorly designed gas stations with even the 28' Luckly, you have a diesel exc so you can use the nice semi lanes at truck stops. That muct be nice...
The only real downside I have encountered is that I no longer fit in one of our favorite state parks. Can't beat sleeping 6 without having to convert a sofa or dinette though.
Go for it. Not that big of a difference.
2008 Keystone Sprinter 299BHSS
2003 Ram 3500 CC DRW 4x4
chevor
US/Canada
I find the longer trailers more stable
2010 Gmc 2500 Duramax,1ton rear springs, 90g box tank, 0ver 497,500 Odometer miles, 20k Curt fifth wheel, 18k Curt rear mount hitch. Cobra CB/Weather Radio, Bridgestone Duravis R500 HDs Rancho 9000 Shocks, Firestone Airbags, bypass oil filter, Fass 95HD
64thunderbolt
Az
ShadySkins wrote: Dick_B wrote: There will be more trouble getting fuel at anything less than a truck stop. We have enough trouble getting in and out of a gas station with our 27 footer. A 34 footer would be almost impossible...
It depends on the setup of the station. I have had no issues if I use the outside pumps. Granted, sometimes I do get in the way of others as I'm waiting on the pump to free up.
My biggest downside is that I can no longer trailer through drive-thru's like I did with my popup.
My truck won't go through a drive through, LOL.
Glen
04 Tail gator XT 34' 5th wheel garage model
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" turbo back exh sys
trucool trans cooler added
08 Arctic Cat Prowler 700XTX
shenandoahvalley
Shenandoah Valley, Virginia
We went from a 30' to a 36'...the weight also increased from about 6500 to about 10200. With the V10 we feel it more on the hills and the mpg dropped some but no problems getting where we want to go, at least so far.
Wumba
Loudon, TN
We just went from 25ft. to 35 ft. NO problems at all towing. Have a Hensley and a P3 brake controller and all is well. As for backing, I actually got it in the spot easier than the 25ft.'er It was our miaden journey and we we're given a pull thru site site. I was determined to back it in (much to the wife's disapproval..lol and did, on the first go.
Opie431
Bellevue, MI
Friends did and found that the kind of places they liked to go to they no longer could. After several months they traded it in for something smaller than they had in the first place.
If you like to RV at RV parks it will work for you. If you want to camp it may not depending on the kind of campsite you like.
dodge guy
Bartlett IL
I tow a 35 foot, 9200lb TT with my X and after a few mods and many trips of tweaking the hitch and moving weight around I have it setup so there is no sway at all. semis can pass me now and it doesn`t even move. it`s all in the hitch setup. and with an Excursion also the rear suspension needs to be beefed up. I added a rear sway bar which helped tremendously and air bags to help with the soccer mom rear springs!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
thib2722
Eunice, LA
We tow a 36 footer, and it tows okay. I have a 2500 Ram Mega Cab (long wheel base) and the trailer behaves reasonably well. The only problem with long units is that you will get some wiggle in the back (fishtailing some call it) and there isn't much you can do to stop it. It's not dangerous or problematic, but you'll feel it. Our previous trailer was a 29 footer, and we didn't experience this problem. Backing a longer trailer, I find, is easier than a shorter one. You have to turn more to get more turn in the trailer, which is nice. One a short unit, a small turn effects a rather noticeable turn in the trailer.
