Does anyone know the hitch height of a Coachman Freedom Express LTZ 191RB ?
I’m setting up a new hitch before we take it out for our first trip, my driveway is not very level, I can’t get a good measurement on it. I called Coachman and the man that I talked to was not sure.
Thanks
Hitch Pin
2012 Coachmen Freedom Express LTZ 191 RB
2012 Silverado LT 1500 with a 5.3
You don't really need level only "even". The rear ground clearance should be the same as the front, even when it's not level (measured from the frame to the ground). YOu can take those measurements even without hitching up, just use the tongue jack to get the clearance even and measure with a tape measure.
Good luck / Skip
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR - 2004 F-150 HD (Traded after 80,000 towing miles) 2007 Rockwood 8314SS 34' travel trailer
skipnchar wrote: You don't really need level only "even". The rear ground clearance should be the same as the front, even when it's not level (measured from the frame to the ground). YOu can take those measurements even without hitching up, just use the tongue jack to get the clearance even and measure with a tape measure.
Good luck / Skip
Good luck / Skip
The ground is not flat.
My suggestion. Pull it out of the drive, and slowly to a close parking lot. check it there.
You could measure from the ground to the bottom of the frame at the axles. Now go up front and figure out the distance from the bottom of the frame to the A-frame and the coupler. Then just add up the separate measurements.
Mike, Barb, and Lilly the Lab
2012 North Trail 26LRSS
Silverado 2500HD, 6.0L gas, 4.10
