2112
Quote: No need to repaint battery compartment,...
Here is an interesting point. Have others using lead acid long term found corrosion to be an issue or problem? Detect any at all? This aspect never crossed my mind.
I'm researching jumping up to the big boys and buying either a class A or C.
2011 Ford F-150 EcoBoost SuperCab, Timbrens, PullRite SuperGlide 2700 15K
2013 KZ Durango 1500 2857
bluwtr49
Green Valley, AZ
2112 wrote: Quote: No need to repaint battery compartment,...
Once again, everything is about care. Properly maintained the battery compartment should remain pretty pristine but if you get careless....well acid is corrosive. Outside of some dust, ours looks like it just left the factory.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
rgatijnet1
The main difference is that with AGM batteries, you install them, set-up your charger properly, and forget them. You pay for this convenience.
With the less expensive lead acid batteries, you install them, set-up your charger properly, you check and add water on occasion, you desulfate them occasionally, you clean your battery compartment from time to time so that you do not have any corrosion, and they will probably last as long as the AGM batteries.
harold1946
Surprise Arizona
Corrosion is always an issue with wet cell batteries with the exception of AGM or Gel-cell. Proper maintenance is the key to keeping it under control. Charging at too fast a rate can cause them to boil as well as too deep a discharge, with the resulting gas-off of hydrogen sulfide.
Discharging below 50% state of charge will also cause them to heat up and can cause the plates to warp, creating an internal short, with the result being a destroyed battery or an explosion. At the very least, the battery life will be reduced. The same can happen if too high of charge rate is applied or overcharged.
edited 07/25/12 08:30am by harold1946 *
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
wny_pat
Western NYS
harold1946 wrote: Discharging below 50% state of charge will also cause them to heat up and can cause the plates to warp, creating an internal short, with the result being a destroyed battery or an explosion. At the very least, the battery life will be reduced.
Which I read about often around here. And both AGM and GEL batteries clearly win out in the Ultra Deep Discharge test.
daveB110
British Columbia, Canada
Never had corrosion with 8 6-volt lead acid wet cell batteries in ten years.
harold1946
Surprise Arizona
daveB110 wrote: Never had corrosion with 8 6-volt lead acid wet cell batteries in ten years.
That is truly amazing!!! Ten years and never had to even clean the terminals.
I think many would like you to share the the secret.
ArchHoagland
Clovis, CA, USA
Well Vanderee, what have you decided.......
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
RayChez
Barstow, Ca. USA
I use the interstate six volt batteries and have had real good luck with them. I also use for cranking the Cat engine heavy duty Napa batteries which are also Interstate built for Napa.
But if you want an expensive battery buy the Odyssey 31M for cranking the engine at $410.00 per battery and that is at a discount. They usually cost over $500.00
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
daveB110
Dielectric silicon with tight connections. No boiling off in a good charging system. I don't equalize, never found a need for it. No "painting the battery area," I still like that colour. Never go less than 12.2 volts. Has worked for me, using four- bank Interstate 6-volts.
