RV.Net Open Roads Forum: PEX & Sharkbite
mbutts
Farmington MI, USA
Posted: 07/25/12 05:22am Link  |  Quote  |  Print  |  Notify Moderator
Can't beat Sharkbite for those cases when you can barely reach the fitting with one hand. Would I replumb a house with them? No, but they are great for inaccessible spots.
Mike Butts
DW+DD+DS+Camping Poodle
2013 Sunset Trail 29SS, 2004 Ford Expedition 5.4L with H.D. Tow Package
swebber
Brunswick , MD
Posted: 07/25/12 06:36am Link  |  Quote  |  Print  |  Notify Moderator
X2
Steve Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
Dakzuki
Carnation, Wa, USA
Posted: 07/26/12 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
I got in a situation replacing an outside faucet where it was impossible to get the plumbing dry enough to solder copper pipe. I kept having water migrate into my job site. The shark bite fitting came to my rescue. I fabricated the section with the faucet separately and then used a shark bite to couple it to the wet house plumbing.
2011 Itasca Navion 24J
95 Chinook Premier
milo
4 Corners
Posted: 07/28/12 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Just finished remodeling both S&B bathrooms. Inserted Sharkbite shut off fittings into the copper waterlines to both tubs & to one shower. Don't know why they didn't put shut offs in when they built the house. I always had to shout the water off to the whole house when working on the bathroom faucets.
Janet(boss)& Milo 36 & 1/4 yrs 2gether
Retired Educators
Mona Mo 6 yr old Yorkie & (in spirit) our Beagle Buddy
13 F-150 Eco Screw HD 4x4 07 294RLS Cougar TT
Confidence is the feelin you have just before you fully understand the situation
Dutch_12078
Great Sacandaga Lake, NY
Posted: 07/28/12 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Add the similar Watts and SeaTech brand fittings to your list. Odds are that a local hardware store will have one or the other, if they don't stock Sharkbite or Gatorbite brands.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
gmctoyman
Lake Livingston, Texas
Posted: 07/29/12 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Butttt, if you EVER have one of these leak where you can just reach it with one hand you better have a palm B. ended up removing the galley sink cabinets to fix a leak on one under the sink. JMOO
Dave W. AKA "Toyman"
KE5GOH - On 146.52
RV's ? What RV's ???
Apache Pop-up
Classic GMC Motorhome
07 Leisure Travel Sprinter
Do Boats Count ?
BarneyS
S.E. Lower Michigan
Posted: 07/29/12 10:48am Link  |  Quote  |  Print  |  Notify Moderator
All you need is the disconnect clip and you can take the fitting apart using one hand. I just did it yesterday while replacing my outside hose bib.
Disconnect clip
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
robatthelake
Vancouver Island
Posted: 08/03/12 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
I wish these were available in Canada! We are stuck with Copper or Pex ...if You can find any! Definately not on every store shelf!
Rob & Jean
98 Dutch Star Diesel Pusher ..92 Tracker 4X2
SCClockDr
SC UpState
Posted: 08/03/12 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
For sweating copper, bread stuffed into the offending leg will stop the water long enough tho get it soldered. It will dissolve and exit the system once you are done.
George & Cathy
08 Titanium 28E33SA, XM, Honda EU 3000is, Trimetric, RotoChocks, LP Reg. Mod, PD 9260 Upgrade, 2 Gal Accum., WiFiRanger GO/Mobile/SKY
04 Ram 3500 5.9 DRW, PAC PRXB E/B, 4" MBRP SS Exhaust, Gauges, Aux Tank/box, BrakeSmart, Cobra (19).
USN Ret
69 Avion
Phoenix, Arizona
Posted: 08/03/12 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
I'd much rather use Sharkbites (or Gatorbites) then crimping.
So much easier IF/when you want to change anything or have another problem.
Yeah...bit more expensive but I like the fact that you can remove & reuse the connectors.
That is a nice feature. And if you don't have the release tool, a properly adjusted Crescent wrench will release the fitting.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
