RV.Net Open Roads Forum: Travel Trailers: From bad to worse....
 > From bad to worse....
Wumba
Loudon, TN
Posted: 07/25/12 05:48am Link  |  Quote  |  Print  |  Notify Moderator
How old is the TT?
gmcsmoke
Butler
Posted: 07/25/12 10:24am Link  |  Quote  |  Print  |  Notify Moderator
HappyTrails2U2 wrote:
jerem0621 wrote:
These delamination post sure make a strong case for the old aluminum sided trailers.
OP...this is terrible and completely unacceptable. Document document document.
Thanks!
There it is! A new record. It didn't take but 3 post on this subject this time to bring out the aluminum siding salesmen.
Aluminum siding; hiding water damage for years
travel-lady
Apple Valley
Posted: 07/25/12 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Wumba wrote:
How old is the TT?
4 years 2 months old......
08 PassPort 245RB
08 Dodge Mega-cab W/Hemi
03 Jayco 10X Quest Pop up
Years of Tent Camping
Pickles the camping Papillon
Leave nothing behind but your footsteps.
jerem0621
Sequatchie, TN
Posted: 07/25/12 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
Not going to hide for years and not a sales man... Just a comment. Wood is easier to DIY repair on. No intention of causing trouble.....sorry
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
westend
all over
Posted: 07/25/12 10:41am Link  |  Quote  |  Print  |  Notify Moderator
What is the duration of the warranty for the exterior?
'03 F-250 4x4 CC
JJBIRISH
Butler, PA, USA
Posted: 07/25/12 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
With as many trailers as I have seen like this I am surprised it took 3 post… if I were the OP I would have mentioned it in my opening post…
It is one reason why I will not own a smooth side trailer… or a aluminum sided one with the IMITATION FIBERGLASS end caps…
This problem happens far to often with all brands and IMO has gotten worse not better… it happens enough they should be required to make buyers aware of it and the policy in place to deal with it…
It happen enough and is expensive enough there should be a class action on them…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
thib2722
Eunice, LA
Posted: 07/25/12 10:56am Link  |  Quote  |  Print  |  Notify Moderator
I had the same thing happen to my Passport. The cost will be about $9K in the end because they will have to replace the entire roof membrane and the front cap. Call your insurance company.
travel-lady
Apple Valley
Posted: 07/25/12 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
You really gave me a scare I called the shop doing the work and he said he has worked on many TT like this and he DOES NOT have to replace the membrane yes he'll be replacing the whole front of the Trailer....Whew..
thib2722
Eunice, LA
Posted: 07/25/12 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Wow... I sure wish the shop I used knew that secret. They had to change the entire membrane and the whole front cap (which comes as one piece). The cost was in the labor. Apparently a lot is involved in removing the membrane and then reapplying a new one and all that caulking and trim work.
Mine started leaking from a hairline crack in the caulking in the front where the roof membrane and front cap met. I check my roof every 6 months, and it wasn't there last time I checked. One day I noticed a small bubble and within days the whole front looked like yours. The guy at the shop showed me why. There is very little wood behind that curved front cap. It's mostly cardboard.
travel-lady
Apple Valley
Posted: 07/25/12 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
Well I was surprised to find out that they used CARDBOARD also.....Did they replace it with plywood and plastic new insulation and a different kind of outer skin? How old was your trailer? Did Keystone cover it?
They wouldn't even hardly talk with us they said if it was the roof that leaked but this falls under maintenance...we do not have extended coverage did you? Ours started the same way first a little bubble and than the whole front.....My husband also checked it every time we waxed it which is about every 6 mo's
