campgrl
Corunna, MI
I am inches away from purchasing a used bass boat. I have checked the laws in Michigan and I will be fine with length. TV should be sufficient as we have a 2500 diesel and our fifth wheel is 8400 lbs dry (boat weighs aprox 1500 lbs). I would like to have any opinions, good or bad, for those who have towed behind their fifth wheel. I plan on getting a hitch welded onto my fifth wheel frame for piece of mind. Thank you!
n7bsn
Yes
Have you checked with your rigs maker to see if the frame is up to this duty? A frame failure could ruin your finances fairly badly.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
bldrbuck
one or the other
It is legal in less thabn 1/2 of the states to double hitch. The advie about checking w3ith the manufacturer is good advice. The limit in length is usuall 70 feet or less. Check with the states you will be in. Good luck.
twinstick
Ball Ground, Ga
I do it. The reason why I went with a 5th wheel. Search my name and you'll fine a lot of pic/post about it
dlturner00
Tennessee
n7bsn wrote: Have you checked with your rigs maker to see if the frame is up to this duty? A frame failure could ruin your finances fairly badly.
Definitely check with the manufacturer. Mine said absolutely not.
2004 F350 CC 4WD DRW Powerstroke
B&W Companion Hitch
Prodigy Controller
2013 Cedar Creek Silverback 35QB4
JIMNLIN
out here
I double towed eight years with a '90 2500 chevy 5.7 engine 4.10 axle with a 26' 7200 GVWR 5th wheel trailer and a 3400 lb bass boat.
I had a custom fabed hitch welded to the trailers main frame rails/crossmembers. No issues.
I drove 5 mph under the speed limits but never over 60 mph. Always plan the route ahead if possible especially some secondary state hiways through towns and maneuvering around fuel pumps.
My boat trailer could be seen in both of my mirrows. By watching the trailer you soon learn not to make those small quick steering input moves but a slower/smoother steering adjustments.
One thing I found was don't mix radials and bias ply tires in the combo.
Keep your speed down and forget about keeping up with the flow.
'97 Park Avanue 28' 5er 11200 gvwr two slides
Memphisdoug
Memphis, Michigan
I have a 29' Laredo and tow my double jet ski trailer behind it all over the state of Michigan. I've never had any problems thus far. The biggest thing to be aware of is your length. It can make some gas stations and parking lots tricky. You don't want to try to back the whole thing up very far.
A friend of mine who is a very good fabricator and welder made the reciever hitch that is on the back of my trailer.
2001 Silverado 2500HD Crew Cab
2003 Laredo 29BH
bad99ram
home
With my old Fifth I double towed with no problems. In Michigan the allowable lenght is 65ft. That is from the front bumper of your truck to the back of the boat. Also, Michigan has a recreational double endorsement that you should get on your license to make it legal. Cost is $15 and it is a written test only. You can get booklet at SOS website ( Michigan).
jalichty
Lander, Wyoming 82520
Towed double since 1993 when we bought our first FW, a Jayco Eagle 215SD. We had the dealer put the hitch on and towed a Bayliner Capri, a SeaSwirl Striper 1850, a Sea Hunt Escape 220 and a Crestliner Superhawk 1900, with no troubles. Purchased a new FW, 2012 Jayco Eagle SuperLite HT 26.5 RLS, had a hitch custom welded on the frame and have pulled the Crestliner a couple of times this year over 300 miles with no problems. I don't believe that over half the states do not allow double-towing, please give us a link to that set of rules.
John A. Lichty
MPI_Mallard
McGregor Ontario,St. Cloud Florida
bldrbuck wrote: It is legal in less thabn 1/2 of the states to double hitch. The advie about checking w3ith the manufacturer is good advice. The limit in length is usuall 70 feet or less. Check with the states you will be in. Good luck. I don't agree with bldrbuck I'm in the process of building a swivel trailer (as soon as honerable son-number-one's new inground pool and landscaping is finished that is)and i'v reserached what states do and don't allow,go for it,just make sure your overall length is good and don't half-azz the hitch and such,do it properly and do it once!!
Edgar Montrose:
(demonstrating how to use a fire-hose to forcibly blast debris
straight up and out of an eaves-trough) Ya know, I think it
was Sir Isaac Newton-John who once said, "Whatever comes
down must go up - - IF ya got enough water-pressure!"
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blücher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
