JJBIRISH
Butler, PA, USA
Normal, no… normally happens, yes under heavy traffic…
preventable, yes with a much better base and installing the absent weep drains before paving… its seldom the concrete itself, mostly base and mud and moisture trapped under the base giving way to the load stress on the leading edge of the pad…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
wbrown62
The problem isn't so much with the concrete pavement as much as it is the quality of work in constructing the pavement. Our past few interstate paving projects that have been concrete are CRCP or continuously reinforced concrete pavement. In other words, no transverse expansion joints. No bumps at all for 6 miles or more except for the couple of punchouts that have occured over the past few years. But what you describe is typical with jointed concrete pavement and expansion will have an effect too as others have described.
2011 Keystone Bullet 246RBS
2000 Chevrolet Silverado
dodge guy
Bartlett IL
Normal! in IL try I355 and I88. I don`t even take these roads anymore they are that bad! and to think you have to pay to use these.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
Chuck&Gail
In the Colorado Mountains
Yes, but it can be especially bad if your tongue weight isn't 13 to 15% of the ACTUAL MEASURED FULLY LOADED TT weight, and/or your WDH has never been set up properly (usually too loose).
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
CavemanCharlie
Storden,MN
Thing is, concrete highways have like a 3 times longer life span that asphalt.
They are usually the best way to go. The concrete is just getting worn out and we have not as a country spent enough money on infrastructure for years.
bigbullelk
Atlanta
Normal. GA 400 and sections of I575 north of Atlanta are just terrible.
coolbreeze01
Redding, Ca
Concrete typically makes nice driveways, curbs, and sidewalks. Asphalt highways are usually smoother, but with enough incompetence, they can be just as rough......
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
eric james
Sioux Falls, SD
I call it "road humping"
DW calls that "inappropriate"
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
NJ6PACK
Neptune, NJ
After I had a shackle brake on me (not related to concrete roads) I installed the Dexter EZ Flex suspension and it does make a difference ....don't get me wrong concrete roads still suck just not as bad
Another trick Ive tried is adjusting your speed . Sometimes I will slow down to 60mph from 65 and that helps a bit
2007 Max Lite ML28 RS
1999 Ford E 350 Super Duty 15 Passenger Ext Van
6.8L V10 / 3.73 Gears
NJ6PACK
Neptune, NJ
