RV.Net Open Roads Forum: Technology Corner: Tailgater problems
 > Tailgater problems
lowreyfarris
Plano, TX
Posted: 07/26/12 11:54pm Link  |  Quote  |  Print  |  Notify Moderator
My tailgater works fine when I run the coax from it directly to the receiver, but when I hook it up to the park outlet on the back of my RV it does not detect the dish. I believe the cable running from the outer outlet to the living room is RG6 but it doesn't specifically say that it is on the cable itself. It does say 75 ohm, which I believe is specific to RG6. Plus it is a 2007. I also hooked up the output of a VCR to the outside and verified there was a signal. It was a bit fuzzy but that VCR hasn't been used in at least 10 years.
Has anyone else had issues similar to this?
I am wondering if the outlet outside of my RV may not be capable of passing the higher frequencies required.
I would also like to k ow if anyone has replaced the cable running thru the walls? As a last resort I may try to run a new cable but want to know if this can be done by coupling the new cable to the old one and just pulling it thru. It is a 2007 Four winds 28A.
Thanks in advance
2007 Four Winds 28A
1999 Jeep Wrangler
Ranger Smith
Wherever the rig is parked
Posted: 07/27/12 04:59am Link  |  Quote  |  Print  |  Notify Moderator
It dosen't find it because that cable on the back is generally for cable TV. If you want to use it for satellite you need to unscrew your antenna booster and remove the cable from it and connect it direct. There are usually 3 cables on the antenna booster. One is antenna in, one goes to rear tv, middle one goes to the outside outlet. Remove the middle one and connect it direct to your receiver and it should work fine
Where I Am Now
Amateur Radio Operator KK9W ARRL VE FT DX2000
Steve and Joy
1999 Winnebago Ultimate Freedom
2011 RAM 1500 Laramie CC 4x4 Hemi
Yogi . . . The Yorkie
Kage . . . The Poodle
Cookie . . . The Chihuahua
Cooper . . . The Aussiedoodle
tvman44
Southwest Louisiana
Posted: 07/27/12 06:16am Link  |  Quote  |  Print  |  Notify Moderator
You apparently do not have a dish ready system, just cable input.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Macktee
Canada
Posted: 07/27/12 06:36am Link  |  Quote  |  Print  |  Notify Moderator
This is what I had to do when I had a TT. It isn't that hard. Macktee
04 Monaco Dynasty Diamond 1V ( Homer II)
2012 Ram 1500 4X4 Quad Cab towed
2011 Dodge Journey
2013 Cargo Mate 24ft enclosed car hauler
Tom and DW Nancy
Holliday Trails member
Good Sam Life time member
FMCA member# F419937
paulcardoza
Southeastern Massachusetts
Posted: 07/27/12 06:43am Link  |  Quote  |  Print  |  Notify Moderator
Just make sure you label any connections you remove as to where they were, so you can put it back the way it was if need be! It can become very confusing if nothing is properly labeled....
P
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
grizzly660fan
Utah
Posted: 07/27/12 10:03am Link  |  Quote  |  Print  |  Notify Moderator
I say start easy and then dig down a layer till you find it. This may be silly but is the tv antenna booster on? if so turn it off. in my case the cable and sat signal will go through the booster as long as it is powered off. If a winegaurd then there is a small black button on the wall plate and a green light indicating if the booster is on or not.
If not, Ranger Smith has good advice.
2012 Epic Voltage 3905
2003 High Output Dodge Cummins
BB_TX
McKinney, Texas
Posted: 07/27/12 10:05am Link  |  Quote  |  Print  |  Notify Moderator
RVs are probably all different. On mine, I had a single coax input for park cable. It went to the ant booster switch box. But before it did, it went into the cabinet behind the TV thru a short coax jumper across two coax connectors. I could remove the short jumper and connect the Dish box to one port. That put the sat coax directly to the Dish box. And I could connect the Dish box antenna output to the other port of the jumper and get the Dish channel to the bedroom TV.
I later installed a second external coax connector for the sat. Now I have the original one for the park cable and a second one for the sat connection.
1995brave
San Antonio, TX
Posted: 07/27/12 10:47am Link  |  Quote  |  Print  |  Notify Moderator
RG-59 and RG-6 are both 75 ohm cables, but RG-59 is only good to around 900 meg where as RG-6 is good to over 1 gig frequency response. Satillite dishes require RG-6 for their LNB to operate properly. Most RVs are run with RG-59 because that is all that is needed for cable and antenna.
lowreyfarris
Plano, TX
Posted: 07/28/12 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
Problem solved!
What I learned; there are different types of barrell connections, with different frequency ratings. The ones with the blue center are able to pass up to 3Ghz and are recommended for satellite connections. The ones with white or grey centers are used for standard cable connections. I pulled the plate off the outer connection and changed the white connector with a blue one (from Home Depot). Problem solved.
Ranger Smith
Posted: 07/29/12 05:03am Link  |  Quote  |  Print  |  Notify Moderator
Kool
