Open Roads Forum
Print  |  Close
Topic: fuel mileage with a Ford F350 diesel
Posted By: tenacioushunter on 07/27/12 09:34am
What can I expect for fuel mileage on a Ford F350 diesel towing a 14,000 pound trailer?
Thanks,
JT
JT
Posted By: downtheroad on 07/27/12 09:39am
What year and engine generation?
Rough guess...between 8 and 12.
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
Posted By: Bigburd on 07/27/12 09:44am
2012 F450 6.7L towing 15000, 12 / 13 by the truck computer.
2012 Ford F-450 CCDRW 6.7L
2013 Heartland Cyclone 300C / Goodyear 17.5" G114's / CarryTank 200
2006 Club Car
Posted By: FrankoToo on 07/27/12 10:03am
With the truck/trailer combo in my sig -
Best 12
Worst 8
A lot depends on type of terrain, weather, driving habits ...
FrankoToo
2012 Heartland Cyclone 3612 HD
2011 Ford F450 6.7L PS 4X4 Crew Cab Lariat
Posted By: Billieg2 on 07/27/12 10:46am
Best 12
Worst 8
2X Same here pulling a 16,500# 5th at 62 mph average.
In my life I've spent my money on women, booze, Harleys, guitars and traveling, the rest I just wasted...
2007 Ford F-350 diesel/dually & Sunnybrook Titan KSRV 39-1 Toy hauler 5th wheel hauling my custom Harley
Posted By: brirene on 07/27/12 11:42am
I'm getting 10.5-12 with my 6.0 towing around 11.5k at 65 or less.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Posted By: agesilaus on 07/27/12 12:46pm
I'm averaging 10.5-11.5 but it can dip as low as 9 with headwinds and climbs. That's based on about 5000 miles on our current trip.
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
Posted By: hallock5 on 07/27/12 12:57pm
13.0, but lighter than most. All terrain, 62mph.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
Posted By: MrWizard on 07/27/12 01:43pm
moved from Technology
Posted By: Wills6.4 Hemi on 07/27/12 01:54pm
08-6.4 towing 8500lb and 1000lb golf cart in bed= 14+ mpg all terrain. So a little lighter than the OP question.
Posted By: Duck on 07/27/12 02:17pm
You are doing much better then mine. My 08 pulling 13,000 pounds get around 10 mpg.
Don
08-FORD F350 PSD
13 Bighorn 3055RL {For Sale}
Posted By: MTPockets1 on 07/27/12 03:56pm
Depends on what engine/yr.... I tow with 2012 F350 6.7..... Our Big Horn Loaded and weighed on CAT scale is 14,000 lbs. Towing from Florida to Texas to Oklahoma, Missouri, illinois, Indiana - so far we are just under 12 MPG when towing..... Our overall MPG, which includes driving un-hitched is 14.3 MPG... Total of 3500 towing miles (I keep a log) and total combined (hitched & un-hitched) miles tracked = 7350
I might add.... When on interstate our best MPG is 55 MPH, but I usually tow at 62-65 MPH..... Usually at 55 MPH on two-lane hwy... Also, If you're in hills you're gonna do less.
2012 3055RL Big Horn - Dexter upgraded axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
Posted By: wintersun on 07/27/12 06:17pm
Your mileage is going to depend a great deal on the terrain and the speed at which you drive. 5th Wheels in particular have a huge amount of frontal area and the wind resistance increases with the square of your speed. At 60mph the wind resistance is four times what it is at 30mph and you need to add in the speed of any headwinds.
I worry more about range with my truck and if you are getting 8 MPG then it is worth considering a larger after market fuel tank.
Posted By: gjwarneke on 07/27/12 02:41pm
2000 F350 7.3 d-turbo CC DW towing #14,500 40ft Open Road Avg. =10.5 mpg
Posted By: souraider on 07/27/12 08:34pm
2006 6.0 towing #12,000 trailer for a #20,000 GCVW averaging 10-12mpg.
'17 F350 STX 6.7
'15 Stealth WA2313
Posted By: kennethwooster on 07/27/12 09:48pm
I've talked to several that pulled up to Colorado from Texas. I live in the Texas Panhandle and the wind usually blows, and of course usually righ on the side. This year it hit on the side so I figured soon as I hit Raton it would be behind me. No still strong sides on the side. Talked to a couple of other Ford truck drivers, and we all got bad mileage. 8 to 9. One was F250 one F350 and a F450 pulling 20000 lbs. Lots of varibles so really hard to tell what you might get.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
Posted By: Retired JSO on 07/28/12 03:25am
Truck, 07 6.0 DRW, 4:10 ratio pulling a 12,000 lb fifth wheel. 65 mph, interstate for 300 miles, hand calculated, 9.8 MPG.
Posted By: YakFishMo on 07/28/12 06:46am
So far, I seem to be averaging between 10 and 11MPG with the rig in my signature. I haven't hit 6000 miles on my truck, yet, and keep hoping that it will improve as she breaks in.
2012 Cedar Creek 36 CKTS
2015 F-350 6.7 CC DRW
Posted By: OldGreaser on 07/28/12 08:28am
2011 F350 duallie towing a 13'6" x 41 ft toy hauler that scaled at 18,275 lb. Best ever was flat, no wind @ 62 mph leading to 10.0 mpg. Worst was about 7 mpg in the mountains. Typical is the mid to upper 8's. For me, the wind is almost as big a factor as the hills.
Posted By: NorthernLimits on 07/28/12 09:00am
2000 F350 Dually 4 door long box. 36 Foot Cardinal 5th wheel. Total loaded weight 21,480. Last trip was just over 7000 miles. Averaged 13.8. High 20.something and low 6.something towing at 60 mph.
Posted By: Billieg2 on 07/28/12 09:45am
I have the same truck and at 55 I get around 12.5 mpg towing. At 60 I get around 11. At 65 I get around 10 mpg. So the numbers really go down with speed. With the 4:10 rear at 62 the tach is right on 2000 rpm. So I would guess with lower gears 3:73 you might get better mpg at a higher mph. It's amazing how the mpg goes down so fast in a few mph...
Posted By: whitebb on 07/30/12 09:27pm
I have a 2012 F-350 heavy Duty crew cab 2wd dually, pulling 16500 5th wheel Montana, 39.6 feet, Pin weight 5500. On regular roads I run say 60 to 65 and average 11-12. One long section in Indiana I got 14, I ask is wow this would be nice. In mountains I get 9.5 10 MPG. I have switched to 5-40 Rotella Symantec I will watch mpg. Just hoping. I only have 15500 mileage at this point. Running empty I get here in Durango CO 18-19.
Print  |  Close
