RV.Net Open Roads Forum: Is it okay to partially extend a Dometic awning?
 > Is it okay to partially extend a Dometic awning?
DHCamper
Michigan
Posted: 07/27/12 04:12pm Link  |  Print  |  Notify Moderator
Can you partially extend a Dometic awning when on a narrow site? If so, what steps need to be taken?
tvman44
Southwest Louisiana
Posted: 07/27/12 04:33pm Link  |  Print  |  Notify Moderator
I have seen it done, don't see where anything special would need to be done.
Papa Bob
Husky 16K hitch, Tekonsha P3,
Old-Biscuit
Verde Valley
Posted: 07/27/12 05:13pm Link  |  Print  |  Notify Moderator
Pull the awning out as far as you want....then slide the top side arms out and lock in place. Then you can decide if you want to extend the side arms.
Just like putting it out normal only shortened up.........
chevyman2
missouri
I have done it many times with the older awnings. If yours is a new powered awning, I know nothing about them. If yours is an older (manual) style awning, you roll it out the distance you want it, then slyde the upper rails to lock like normal.
Tim-DW(Kathy)
12 Chevy Sonic DD, 03 JEEP GRAND CHEROKEE, 2001 Jayco KIWI
If a "nightmare" is considered a dream-then I am living the dream
LadyRVer
Posted: 07/27/12 06:27pm Link  |  Print  |  Notify Moderator
I extended my power awning just a few feet due to a tree in the way. Worked fine. Just recently traded and now back to a manual and trying to figure out how to do that one.. first time I opened it too much, door wouldn't clear and no room to raise it. So, had to roll it back up and start over. When the dealership did the walk-through they said I could partially extend it. So, after 3 power awnings, have to relearn the manual one.
DHCamper
Michigan
Posted: 07/27/12 06:41pm Link  |  Print  |  Notify Moderator
Thanks I did partially extend it and it works fine. The only thing is that the spring inside the roller bounces when you walk in the trailer.
thib2722
Eunice, LA
Posted: 07/27/12 07:04pm Link  |  Print  |  Notify Moderator
Our dealer said that you could partially extend but that they are designed to be fully extended. It's only at full extension that the "support" arms work as designed. They may have been full of hot air, but that's what they told us during the delivery walk through.
jjjandrbaker
San Antonio, TX
Posted: 07/27/12 08:12pm Link  |  Print  |  Notify Moderator
I did that a few weeks ago. I didn't notice that there was a pole in the way of the awning. It didn't hurt a thing. Today I did it again to just put shade where it was hitting my window.
Jim Baker
San Antonio, TX
travel blog and photos
facory
Georgia
Posted: 07/28/12 07:47pm Link  |  Print  |  Notify Moderator
Old-Biscuit stated the key factor. You should be able to extend it far enough so that the support arms will attach to the roller at their minimum length. That will give the awning enough support.
2008 Cruiser RV Fun FinderXtra
Ford F150 Lariat 4x4 SuperCrew 5.4L 6.5' Bed 150" WB 3.73
Schwinn Mountain Bike
johntank
North MS
Posted: 07/28/12 09:12pm Link  |  Print  |  Notify Moderator
I have mine out like this now, the only thing I do with mine is to leave the roller springs in the retract position so they keep tension on the awning.
