RV.Net Open Roads Forum: Would Stable Loads be a help in my situation?
 > Would Stable Loads be a help in my situation?
JumboJet
Tontitown Arkansas
Posted: 07/28/12 06:16am Link  |  Quote  |  Print  |  Notify Moderator
From my experience, Stable Loads do not collapse or clunk when they make contact on my 2008 Dodge 3500 with a Lance 1050S.
They engage sooner (less squat) and stay engaged when the TC is loaded.
One of the best things I added to my truck along with the Hellwig sway bar.
BradW
Mayor of Flat Rock
Posted: 07/28/12 06:54am Link  |  Quote  |  Print  |  Notify Moderator
Crazy Creek wrote:
OEM Shocks....
If you have an SRW truck or the shocks are old, you might consider replacing them with Rancho 9000's. They won't stop the side to side rocking when exiting a driveway diagonally, but they will damping the rocking motion much quicker.
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
Farmerjon
Niangua, missouri
Posted: 07/28/12 07:53am Link  |  Quote  |  Print  |  Notify Moderator
my overloads weren't being engaged enough so I made some bumpers and it really made a big difference on the sway especially in driveways. The rocking and rolling wasn't horrible but it is much less now.
s
00 F350 SC LB 4x4 DRW 7.3 PSD 6sp 3.73 DYI over load bumpers
99 Starcraft 953
87 F250 460 4x4 4sp 4.11 ex cab 8ft
95 jeep YJ 4cyl 5sp
69 f250 360 4sp
BradW
Mayor of Flat Rock
Posted: 07/28/12 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
s
Was it difficult getting that rubber pad out of the factory bracket?
Are those 1/2" bolts?
Thanks,
Brad
Farmerjon
Niangua, missouri
Posted: 07/28/12 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Brad
Yes they are 1/2 inch. That was the size of the slot so I went with it to keep movement down and used 2 bolts to stop any twisting.
The 1st pad was difficult because I didn't realize how hard I would have to pry. After the first one the others seemed easy . Use a large screw driver or small pry bar.
also some silicon spray helps them slip in and out easier.
Jon
* This post was edited 07/28/12 04:00pm by Farmerjon *
Boatycall
Tacoma, WA
Posted: 07/29/12 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
d3500ram wrote:
clinthia wrote:
Not sure what kind of truck you have, but this is what I did to my Dodge.
Following Clint's lead I did the same to my Dodge with very satisfactory results. These are solid whereas I think that the SL's collapse when load is applied (not positive on that.)
It just so happens, I just visited their factory in Sumner WA last week and got to talk at length with the General Mgr and Senior Development Engineer.
Stable Loads have a solid steel core, and the area on the bottom that contacts the spring can be trimmed if needed, but no more than 3/8" or it will expose the steel block inside.
So in essence, they're basically what you just built.
01 F350 DRW 4x4,Torklifts,SuperHitch,F550 Rear Suspension,Roadmaster ANTI-Sway Bar,Rancho 9000s
2012 AF 1150-4 Trojans,1.5kw Inverter,32" LCD,19" LCD,Basboard heat,Dish Tailgator,Ice maker,3 awnings,80a charge circuit,Polk Audio/Kenwood/Kicker sound system
Bedlam
PNW
Posted: 07/29/12 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
I experimented with my stock stops and offset blocks prior to using the Energy Suspension stops. When loaded, the overload springs were always in contact and it was great. When unloaded, rough roads would make the overloads contact and break with the offset stops resulting in a thump. The stops I selected compress about 50% of their height which does not give me as much spring preload at the same ride height, but makes the unloaded ride very close to stock.
Arctic Fox 811S-Ford SuperDuty F250-Honda Passport C70B-Interstate 20' Car Carrier-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX-Tank Touring 150SE-VW 1300sp-VW Jetta TDI
View my profile for rig details.
Roadlover
Petoskey, MI
Posted: 07/30/12 05:17am Link  |  Quote  |  Print  |  Notify Moderator
I can only speak from my experience but the Stable Loads made a phenomenal difference in our ride. This past winter, my wife and I took a 4000 mile round trip down to the Florida Everglades and Keys and I was very impressed with how well our truck handled with our AF 1150 sitting on its back. For such an inexpensive investment, I would highly recommend giving them a try.
"The Journey is the Destination"
2004 Chevy Silverado 3500 LT Duramax/Allison DRW 4X4
Banks Powerpack, Sprayed-In Bed Liner,
TorkLift Tiedowns, StableLoads, FastGuns with Locks and RideRite Air Bags
2012 Arctic Fox 1150 Truck Camper and Dry Bath
d3500ram
colorado
Posted: 07/30/12 05:30am Link  |  Quote  |  Print  |  Notify Moderator
I could not remember the ones that collapse... the photo posted after me show the one's I was thinking of... it is the ones from Energy Suspension that compress under load.
mountainkowboy
Socal High Desert
Posted: 07/30/12 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
The stableloads did wonders for "red", without them my S&S would set the truck down level. A drop of 4-5 inches, with them I only drop about 1.5 inches and my handling is much better. My truck has the camper package, so I have the large swaybars front and rear along with the upgraded rear spring pack. I also have Bilstien shocks all around, the truck knows it back there, but it really drives nice considering I'm at GVWR to a little over most of the time.
Chuck & Ruth with 4-legged Dixie & Hanna
90 F350 S/C Dually, Camper Pkg, 460/ZF 5spd, Banks Powerpack, Torklift Superhitch/32" extension.
90 S&S 11 SCB
94 Alpenlite 29RK DL
06 CRV
64 IH Scout 80
