RV.Net Open Roads Forum: Replace audio system
Cheyenps
Yorba Linda, CA
Posted: 07/27/12 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
My trailer came with this typical audio unit.
It doesn't sound very good and now the CD door is broken. I'm going to replace it.
In my last trailer I replaced a similar unit with a regular car stereo unit. To adapt the cutout size I got a cabinet door to match the other cabinet doors in the trailer and mounted it through that. The cabinet door wasn't a perfect match with the "paneling" but it was as close as the other cabinet doors were and I left it at that.
For this trailer I am having a hard time thinking up a way to mount a car stereo in the cabinet nicely enough that it looks like a factory installation. Suggestions?
A 120 volt "bookshelf" system would be the right shape - has anyone installed one of those with an inverter?
Steve
2008 Thor California Summit 26RLS
2003 Ford F-350 SRW Crew Cab Utility
Kiwi_too
Western, WA
Posted: 07/27/12 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Do you boondock?
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
ianblaster
Dothan, AL
Posted: 07/27/12 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
You could have a local machine shop fab you a plate for it to match the panel below your stereo. Something that size should be relatively cheap.
2007 Expedition EL Limited 4x2 w/Tow Pkg
2009 KZ Spree LX 318 BHS
Tom&Dale
Manhattan Beach, CA
Posted: 07/27/12 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
My conversion might not be up to factory standards but it's close enough for me. Also made a mount for the iPod, using Apple's standard USB connector, so it can be controlled via the radio's remote.
We boondock mostly so I like to stick with 12 volt as much as I can.
Good luck,
Tom
02 Dodge 2500 CTD, Edge EZ, Goerend transmission (3.55 axle ratio), BrakeSmart, BD exhaust brake, Firestone Ride-Rite air bags, Husky 16K hitch & towing our 05 Americana LC30/31 RL
MitchF150
Washington, the State
Posted: 07/27/12 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Here is what I did with my space. I built the box as it's own unit to the dimensions of the hole the OEM unit left. Slide it in and attached it from inside the cabinet.
I use the upper space for the iPod, CD case, remote, whatever and works very well for me.
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
btmfdr
Barnegat NJ
Posted: 07/27/12 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Mitch
Very nice Mod Mitch...
Current Setup
1997 Suburban 2500
2012 Rockwood 8312SS
Previous Setup
2002 Suburban 4x4
2002 Jayco Kiwi Too 30T
Cheyenps
Yorba Linda, CA
Posted: 07/27/12 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
Kiwi_too wrote:
Do you boondock?
Yes, but not for long periods at any one stretch. Maybe a couple of days, max.
Would a 120 volt unit with an inverter draw much more power than a 12 volt unit?
That's a great idea!
Cheyenps
Yorba Linda, CA
Posted: 07/27/12 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
Mitch
Super nice! I really like the idea of including the extra box above the head unit.
westend
all over
Posted: 07/28/12 02:45am Link  |  Quote  |  Print  |  Notify Moderator
Nice work, Mitch, I like the rope trim!
I don't know, exactly, about RV players but all auto players follow DIN sizing and there are after market pockets or filler plates down to half-DIN sizing. The OP should be able to pull the oiginal player and install an auto player, filling any voids with aftermarket fill plate or pocket pieces.
'03 F-250 4x4 CC
ronfisherman
SE Michigan
Posted: 07/28/12 03:32am Link  |  Quote  |  Print  |  Notify Moderator
I have made some good looking factory like panels out of black King Starborad. It cuts with normal wood tools. Here is my latest use of Starboard. Not finished yet. Going to be a AC display yet.
Kodiak Chassis Class C Forum
