RV.Net Open Roads Forum: Class A Motorhomes: Workhorse speedometer
 > Workhorse speedometer
D & M
Laurel, MD
Posted: 07/28/12 06:54am Link  |  Quote  |  Print  |  Notify Moderator
I know this has been asked and answered several times, but will someone be kind enough to refresh my memory on how to clear the "change oil now" message on the odomoter of a workhorse chassis.
Thanks
Dave
Mary, the world's best wife (1951-2009) R.I.P
Lizzy (the Boston)
Izzy & BuddyP - Gone but not forgotten
2005 Itasca Suncruiser 35A
Talk is cheap because supply exceeds demand
Bob & Ann
Vinemont AL
Posted: 07/28/12 07:20am Link  |  Quote  |  Print  |  Notify Moderator
I would have to get the book out but it has to do with the gas pedal. I believe that you turn the key to accessary. Push the button by the odometer and pump the gas pedal five times. Then turn the key to start the engine. If you need for me to I could go out and look at the book.
Bob and Ann
One HAPPY Schnauzer - Della
One FRISKY Chihuahua - Lola
2005 37 DB Allegro Bay
Workhorse Chassis
GM 8.1L (496 CID)
340 HP
Onan 7000 Watt
Double Slide
2006 Suzuki Grand Vitara Toad
wilanddij
CA Desert
Posted: 07/28/12 07:29am Link  |  Quote  |  Print  |  Notify Moderator
I think it goes like this. With the engine off, keep your foot off the brake, turn the key all the way to start, pump the accelerator 5 times.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
Tom N
Sarver, PA/Crystal River, FL/Shelocta, PA
Posted: 07/28/12 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Quote from the 2006 Gas RV Workhorse Maintenance Guide below.
"To reset the oil change reminder, turn the ignition switch to the “ON” position but do not start the engine. Fully depress and release the accelerator pedal three times within five seconds, and turn the ignition switch to the “OFF” position for at least 10 seconds."
-Tom
Sarver, PA/Crystal River, FL/Shelocta, PA · W3TLN · FMCA 335149 · Mystic Knights of the Sea
2005 Suncruiser 38R · W24 chassis, no chassis mods needed · 2012 Honda Accord EX-L · 2008 Honda Odyssey EX-L
Bob & Ann
Vinemont AL
Posted: 07/28/12 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Got to thinking about it and just went out and got the book. The book says:
1. Perform oil change
2. Turn ignition switch to on position but do not start the engine.
3. Fully press and release the accelerator petal 3 times within 5 seconds and turn the ignition switch off for at leasst 10 seconds.
4. Oil life counter on the engine controller will be reset to start a new cycle.
Hope this helps
D & M
Laurel, MD
Posted: 07/28/12 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys. I knew there was some pump the gas pedal trick but I could remember the sequence.
