RV.Net Open Roads Forum: Toy Haulers: AC Not Keeping Up
Search only in Toy Haulers
 > AC Not Keeping Up
grizzly660fan
Utah
Posted: 07/28/12 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
Doing some summer camping in our voltage 3905 this weekend and it is hot in southern Utah. We opted to stay in an rv park with full hook ups.
Wanted to ask if anyone has any tricks for helping the AC out? Seems the inside RV temp is about 15-16 cooler than outside air temp. As an example the last couple of days has been hitting 100-102 as a day time high and inside RV is hitting 84-85. Is this normal?
Our voltage does have the dual AC option and we are running both units connected to 50amp service.
2012 Epic Voltage 3905
2003 High Output Dodge Cummins
Strabo
Host "AGW-RALLY'S"
Posted: 07/28/12 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty much normal for that size hauler, worse if its humid
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 660 SS106-ITP-K&N-JetKit-T4-CDI-CVT-Grant-Holder LED LightBar-HID Conversion Kit-UV Whip
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
ScottG
Bothell Wa.
Posted: 07/28/12 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
Put some of these pillow thingys in the roof vents - they're a huge source of heat.
Scott, Grace and Wesly
H0NDA eu2000i
2btowed
glendale,az
Posted: 07/28/12 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 20x40 tan sun shade netting that I use to shade the top and the west,or sunniest side.This is 90% block,and it makes a big difference on TH inside temp.Also have the aluminum waffle insulation from Home Depot ,cut and stuffed in all the windows.If we camp at the Lakes around here in the summer,its the only way we can survive.Also have two AC's crankin and 2 12v Fantastic fans blowing the air around.I also pre-cool the TH at the house before we leave..Anything you can do helps out.good luck
08 Ranger
08 Grizzly x2
06 400ex
06 Honda 90
04 Kymco 110
Strabo
Host "AGW-RALLY'S"
Posted: 07/29/12 12:05am Link  |  Quote  |  Print  |  Notify Moderator
Aluminum waffle roll stuff is the hot ticket, i also have it in almost every window even with our grey lite 31 tinted glass, works great, and we use the vent pillows. But then again we have a 4 1/2 ton Areocool swamp cooler system that does the job even if its 118 here in the desert.....I custom made it.
Old-Biscuit
Across the USA
Posted: 07/29/12 12:25am Link  |  Quote  |  Print  |  Notify Moderator
This post is useless without pictures.......
Block windows.....Reflex thinsulate (Home Depot, Lowes etc.)
Awning out for some shade effect.
Block the skylight/vents
Crank up the A/Cs early
Clean filters
Run A/C fans on high setting
As a last resort take turns sticking your face in the freezer section....don't touch anything with your tongue
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
joeprinter
Fayetteville, NC
Posted: 07/29/12 03:32am Link  |  Quote  |  Print  |  Notify Moderator
I have a thermal blanket over my front windshield, not a great view, but sure keeps the cold in.. as mentioned the reflective windshield sun shades are nice too..
"2012 Forest River 360 DS"
"Ford V-10"
"2013 Toyota Corolla on Tow Dolly"
joeprinter
Fayetteville, NC
Posted: 07/29/12 03:39am Link  |  Quote  |  Print  |  Notify Moderator
We like to start here first , fun to watch...
mpierce
Scranton, ND
Posted: 07/29/12 05:50am Link  |  Quote  |  Print  |  Notify Moderator
How much air moves out of the main AC ducts? There are quite a few of them, but it sure does not seem like much comes out of each one. The AC in the front bedroom puts out a lot, but is just one spot.
dan-nickie
Grand Prairie, TX
Posted: 07/29/12 06:20am Link  |  Quote  |  Print  |  Notify Moderator
The 'aluminum waffle' mentioned above is called 'Reflectix'.
It is the instant, inexpensive cure and can be found at home depot or lowes.
You must stop the heat wherever it is coming in.
Cover the affected windows, vents, skylights, maybe windshield.
It will get nice and cool inside then.
A fan or two to move air also helps.
Dan and Nickie, Four Winds 31p, Retired Jan/2011
 > AC Not Keeping Up
