roughingit???
Lancaster P.A.
I have a Sunline T-2670 and my problem is a sooty hot water heater, when I use the gas mode the heater leaves a big black sooty grime on the side of the aluminum siding above the exhaust . Is it dangerous? Can I repair this myself? Is this normal? Any help you can give me is really appreciated.
2001 F-150 Supercrew
2003Sunline t-2670
Yellow lab, other half, 2 kids
DO N DAT
Antioch, Ca
I would suggest checking the area where the flame is for an obstruction. Such as insects or debris. And including the tube where the flame exits the tank.
1999 Ford F350, 7.3 Diesel, 2003 Triumph 365L
rockhound007
truck
it has to do with improper combustion. As someone else said, check the burner for a blockage or partial blockage, sooting is an indication of burner too much fuel.
dbbls
Missouri
If you don't find any obstructions as the previous poster have suggested, adjust the air tube at the burner. Slide it to give more air.
I'm guessing you will find a spider web in the air tube.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
nelson
Clio,Mi USA
On mine I changed the rusted burner tube and that took care of the sooting
2002 Damon Challenger 348 Ford V10
Blue Ox Auto Stop and Aventa II Tow Bar
2001 Ford Sport Trac with Remco Driveshaft Disconnect
Fire Instructor
Upstate (Albany) NY Area
In terms of owner-done RV maintenance, this isn't a tough job. They even sell a little flex-brush for keeping the burner tube clear. That said, if you don't have the owners manual or if you aren't familiar with what you are doing, find someone who is to do this work or to show you how. Most likely, a local propane company has a burner tech who can clean the unit and adjust the burner in adjust a few minutes. Since you can bring the burner to them, they likely won't bang you for a full-cost service call. Regardless, it will probably be done better and less expensively than letting the 19 y/o "technician" at the local RV dealership do it.
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
300 Watts of SunTech Solar Panels
Rogue MPT-3024 Controller & Xantrex PW2000 Inverter
"If everyone is thinking alike, then someone isn't thinking!" General George S. Patton
robatthelake
Vancouver Island
Adjust the Burner Tube! One little screw...loosen and slide the tube left or right to increase air flow. Too far and it will sound like a Jet Engine.
Rob & Jean
98 Dutch Star Diesel Pusher ..92 Tracker 4X2
Old-Biscuit
Across the USA
CAUSES FOR SMOKING AND SOOTING
Gas pressure incorrect --------------Set pressure to a minimum of 11? W.C. with two or more appliances running
Poor gas supply ---------------------Replace gas supply
Improper pilot flame ----------------Clean or replace pilot orifice
Improper air adjustment -------------Adjust main burner air shutter approximately 1/4 open
Flame spreader mis-aligned ----------Re-align or replace main burner
Blocked main burner -----------------Remove blockage
Improper main burner alignment ------Re-align main burner, main burner orifice holder and gas valve
Blocked āUā tube --------------------Remove blockage
Clean burner tube and the 'U' tube (heating/exhaust tube). Blowing out with air will remove debris BUT will not get rid of spider webs. Spider webs are the biggest cause of 'obstructions'. Spiders LOVE the smell of propane. Run a bottle brush thru 'U' tube (need to remove burner tube for access)
Then run brush thru burner tube..re-install and then adjust air shutter. Blue flame with tinge of yellow at tip and fairly quiet.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Ex-Tech
West
Note that not all water heaters have an air shutter and a pilot light.
Also, having serviced RV's for over 25 years, I still have yet to understand how burner tubes, gas valves, flame spreaders and other parts that are phsically bolted, screwed, welded or rivited to an assembly, all of the sudden magically move on their own so an adjustment is needed. (?)
Unless, of course, something physically hit and then damaged one of the afore mentioned parts.
pkunk
Questa, NM
Ex-Tech wrote: Note that not all water heaters have an air shutter and a pilot light.
Unless, of course, something physically hit and then damaged one of the afore mentioned parts.  Bouncing down our wonderful highways occasionally moves my air shutter and I also re-adjust it depending on altitude. There's a big difference in air need (for combustion) from sea level to 10,000ft. The more one adjusts them, the more apt they re to move on their own.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
