campgrl
Honor, MI
I know someone who can weld a hitch onto my frame to save $$. My question is will a mig weld be strong enough to weld a hitch onto the frame to pull around 1000lb bass boat?
xPIXx
MO
I was a welder for 15 years, mig will be fine.
lawaco12
gallatin tn
no mig welding will burn deep enough or have big enough weld
TGarrett
TN/SC
If your welder doesn't know what kind of weld is required or if his weld will hold, do you really want him to weld it?
Garrett
2004 Fleetwood Expedition 38N
Full Timer
Toad(still to be setup) 2011 Jeep Rubicon
2nd (to be put on double trailer with 1st when moving) 2008 Honda S2000
campgrl
Honor, MI
He says it will hold. I just wanted another opinion. Thanks!
SoCalDesertRider
Arizona desert
I would weld it with 7018 stick or E71T-11 fluxcore wire. Mig with ER70S-6 and 75/25 Ar/C02 will work too. Tig would be a waste of time and money in this application.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
SoCalDesertRider
Arizona desert
Much more important than the welding process you use, is proper prepping of the metal. Remove all paint, rust, dirt and grease from the areas to be welded.
SDM
KANSAS CITY MO.
Worked in weld shop for 30 years. If everything is properly cleaned and prepared the mig weld will be fine.
JIMNLIN
Oklahoma
A mig weld will hold fine when done by a compentant weldor and have plenty of penetration. Stick/mig or tig , take your choice.
I would prefere a mig for that type of work.
bpounds
Senile, er I mean
Your trailer frame was built using MIG. Why would it not be good enough?
There is nothing inherently wrong with MIG. Like anything, just has to be done correctly.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
