RV.Net Open Roads Forum: Dinghy Towing: Blue OX Towbar broke in half!!
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  Tow Bars
 > Blue OX Towbar broke in half!!
willald
NC
Posted: 07/30/12 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Healeyman wrote:
...I presume that the damage to the car occurred when you stopped the RV and the car ran into it? Correct?
Didn't the onboard braking system and breakaway feature stop the car. OR DID IT???
I would think that most regular onboard braking systems would NOT engage in this situation, unless it was one that could manually be engaged by the driver in the MH (some have that, others do not). AND, the driver was able to reach over and manually engage the toad brakes before the toad ran into back of the MH/tow bar.
As far as breakaway system goes: OP said that car was still attached by safety cables, so in that case many breakaway devices would NOT engage.
..This kinda brings up the question, of whether one would want a breakaway device to engage while car is still attached with just safety cables, or if it should not engage until/unless total separation occurs. I've seen arguments both ways, but what happened here seems to suggest the breakaway should engage before total separation. Might would have prevented any damage to the toad vehicle in this case.
Anyway, do keep us informed of this, I'm curious to see what Blue Ox does for you in this circumstance. Some pictures would be nice, too, as already mentioned.
Will & Angela
2 children that love camping, Stephen & Allison
2012 FR Georgetown 351DS on F53 (V10) Chassis
Our Rig
stillgoing
Clemmons
Posted: 07/30/12 09:56am Link  |  Quote  |  Print  |  Notify Moderator
I had a brake system on the tow car but when the bar broke it pulled the air hose loss from the car. If you look under the hood of a Terrain there is no place to put a break away cyliner under the hood or anywhere else. I don't think it would've helped anyways because the safety cables would have pulled it till the cylinder released. I would be glad to send pictures if I knew how you do it on this web site. Blue Ox told me to send them the old bar and after they checked it out they would either replace it or offer me a large discount, even though it is 12 years plus.
willald
NC
Posted: 07/30/12 10:42am Link  |  Quote  |  Print  |  Notify Moderator
..Check out the ReadyStop (RS-5000) product that Readybrake offers. Real simple, independent, cable-operated breakaway system, that I bet will work fine in your Terrain. Our Kia Sedona is VERY crowded under the hood as well, but we were able to install the Readystop on it.
Might be something to think about for the future, even though the chances of you having ANOTHER break-away incident in this lifetime are pretty slim. Lightning rarely strikes the same place twice, haha.
Wow, thats great. Great to see they're standing behind their product even long after warranty has expired. Wish more companies would do that.
Will
wny_pat
Western NYS
Posted: 07/30/12 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
X - 2!! I use it also.
and stillgoing, glad they are taking care of it.
bigred1cav
ohio
Posted: 07/30/12 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
wny_pat wrote:
portscanner wrote:
pix?
X - 2. 12 years old??? Has it received the required periodic maintenance? In following the pretrip safety inspection did you notice any cracks in the welds? I really doubt, with a 3 year warranty, that they will replace it. But I believe they will offer you a liberal trade in credit.
Where may I get the maintenance?
enblethen
Moses Lake, WA
Posted: 07/30/12 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
Your owner's manual should have asection about taking apart, cleaning and reassembly.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
univmd
Maryland
Posted: 07/30/12 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
In 2011 Blue 0x beefed up their aluminum Alladin from 5,000 to 7,500 lbs.
2008 Gulfstream Tourmaster
2011 Honda CRV
Blue Ox Baseplate & Socket Wiring
Blue Ox Alladin Tow Bar
US Gear Unified Tow Brake
wny_pat
Western NYS
Posted: 07/30/12 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
Your Blue Ox Owners manual tells you what is required. The following it the maintenance for the Aladdin BX4325.
"Tow Bar Maintenance
1. This tow bar requires periodic maintenance.
It will be subjected to road dirt and weather
during use. The following tips will help
maintain the condition of your new tow bar.
2. Keep the tow bar covered when not in use,
on or off of the towing vehicle. This will cut
down on the dust and dirt build up on the
legs and latches of the tow bar. A BX8875
tow bar cover is recommended.
3. Periodically clean the entire surface of the tow
bar with a mild soap and water solution. Wipe
dry with a clean cloth.
4. Check and replace any loose, worn or
damaged bolts, rubber boots or cap plugs.
5. Check for cracked welds and loose bolts
on the baseplate, towed vehicle (where
baseplate is bolted) and the hitch on the
towing vehicle.
6. In normal straight line towing conditions, both
legs will be in tension. Due to the design of
the latch, both handles will feel loose. During
turning, braking or parking one or both of the
legs may be in compression. This will make
the handles feel stiff or tight. Due to parking
on slopes or the angle between the coach
and the car, the two locking mechanisms
could be in compression or tension or any
combination of the two. Having one lock in
tension and one in compression may give
the operator the feeling that one leg is locked
and one is not, when in fact whenever the
legs are fully extended and the springs are
holding the latch handles up, the legs are
locked and ready to tow whether in tension or
compression."
bigred1cav
ohio
Posted: 07/31/12 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, do you know where I get it professionally serviced without shipping it to factory?
towing vehicle.
compression."
enblethen
Moses Lake, WA
Posted: 07/31/12 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Most RV shops will do it.
Some auto/truck repair will do it. However they may need a kit. If yours doe3sn't have rubber boots, then you should get the kit and have it installed.
