RV.Net Open Roads Forum: Fifth-Wheels: Help with toilet!
 > Help with toilet!
jwduke
Ice Cream Capital of the World (Le Mars), Ia.
Posted: 07/29/12 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Our toilet (Thetford Bravia), I found was leaking. I was finding moisture running down the pipe, so I removed the toilet. Upon removal, it looked like the foot valve was leaking (It wouldn't keep water in the bowl, either).
Sooo, I check for parts. A new valve is $68+ shipping, and floor gasket was $25 with shipping. So we decide to buy a new toilet (Dometic 510H).
I installed the toilet, it works great, and we love the height of the toilet.....
But it is leaking like the old toilet! I am not finding moisture anywhere on the floor.
Do I need a new flange or......Thanks for any or all help!!!
'04 Dodge 2500 QC 4x4 w/CTD
'03 Hitchhiker II 31RLBG
Dave H M
IL
Posted: 07/29/12 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
where is it leaking if no water on the floor?
if it is the water leaking out of the bowl, you should be able to get some resolution from where you bought it.
rattleNsmoke
Western Conn.
Posted: 07/29/12 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure the water line isn't leaking.
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Posted: 07/29/12 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Try tightening the closet bolts a little OR, if you made them too tight, try loosening a turn or two.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, ClearSpot 4G+,
http://www.kayepics.com
jwduke
Posted: 07/29/12 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
The toilet is leaking around the pipe in the basement....
rattleNsmoke
Western Conn.
Posted: 07/29/12 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
With that explanation in mind.....p\u a new flange. You really should have sprung for that initially.
Mike
jwduke
Posted: 07/29/12 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Mike
Mike, quick question, after you remove the screws, does that flange screw out? THANKS!!
Our Place
Southwest Ohio
Posted: 07/29/12 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
You might have to cut the pipe in the basement to replace the floor flange. Sound like its cracked and leaking water around the "outside" of the waste pipe. It really is a simple fix if you have good access to the pipe.
2001 GMC 2500HD 4x4 with 8.1 gas Allison trans
2011 Coachman Chaparral 268RLE "Campy"
jwduke
Posted: 07/29/12 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
That's exactly whats its doing. I do have a easy access to it in the basement.
wvcampers
United States
Posted: 07/29/12 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
First try using a wax ring with the extension, just like the one that Lowes sells for less than $5.00. I am not sure why RVs have a rubber gasket, maybe that it easier to handle at the factory and not as messy, but the wax ring will work fine.
 > Help with toilet!
