RV.Net Open Roads Forum: Technology Corner: Tailgater mount
 > Tailgater mount
Fire5er
Port Orchard, WA
Posted: 07/29/12 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
How do you mount your Dish Tailgater when in use? Would like to see some DIY type mounts if any of you have made and use them (pictures would be the best). Right now I just put the Tailgater on the roof when in use, but I am getting tired of climbing up and down the ladder of the fifth-wheel with the Tailgater dish in tow.
2011 F350 CC, 6.7, LB, DRW.
Hijacker (24-UMS-21) 21k Underbox Hitch.
2007 Keystone Montana 3400RL (38'9")
PressurePro Tire Pressure Monitoring System.
ADAD437
New Albany,Ind. USA
Posted: 07/29/12 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
I will be following this as i do not want to pay the ridiculous price they want for them.
James,Gail & Pancho
2005 georgie boy Pursuit
Denny & Jami
Home Base Nebraska
Posted: 07/29/12 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a link to one I built and one that someone else built. link
Denny
2013 F350 SC DRW 6.2 V8 4.30 gears Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Sumitomo tires
Kiwi_too
Western, WA
Posted: 07/29/12 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
Denny
user account needed for the link.
I believe the VuCube mount works. See PPL Motorhome
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
ADAD437
New Albany,Ind. USA
Posted: 07/30/12 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Kiwi_too wrote:
Denny
I know the vuCube works but i refuse to be robbed.
paulcardoza
Southeastern Massachusetts
Posted: 07/30/12 06:22am Link  |  Quote  |  Print  |  Notify Moderator
The VuCube mount will work as the tailgater is just a simplified version of the VuCube 2000. We have the mount attached to the ladder and is locks the unit in very securely. Works great and there's no need to take it down to operate as long as you have line of site.
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
Fire5er
Port Orchard, WA
Posted: 07/30/12 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies, but I am with ADAD437...I refuse to be robbed. I am looking for a DIY project type of mount. I think I can come up with somthing for way less and that will work just as good if not better.
As for the ladder mounts, I would still have to climb the ladder to get the dish above the roof line if the back of the 5er isn't pointing south.
grizzly660fan
Utah
Posted: 07/30/12 10:59am Link  |  Quote  |  Print  |  Notify Moderator
I usually just set my tailgater on the ground or on a table, we park in many different orientations so a single mount on my trailer might get the view to the sky blocked by trees, mountains, and other obstacles.
I have a cable lock that I lock the tailgater to my trailer with in case someone decides they have sticky fingers and want to take it. true my lock and cable could be cut but the same would be true if you build a mount on the RV that they can also cut whatever you have set up.
2012 Epic Voltage 3905
2003 High Output Dodge Cummins
paulcardoza
Posted: 07/30/12 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Hmmmmmmm...... I'm sure if you are a handy type, you can come up with something for less than the $100 cost of a VuCube mount. HOWEVER, be aware that you have some facts wrong. If mounted properly on the ladder, as recommended by VuCube, the antenna will have 360 degree view of the sky. I only have to take mine down if there are trees in the way, no matter which way my campsite is facing.
For me, not being very handy, the $100 was money well spent......
ADAD437
New Albany,Ind. USA
Posted: 07/30/12 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Hmmmmmmm you haven't checked the price of late have you. try 170.00 and up.
 > Tailgater mount
