Monty-Rob
Sioux Falls, SD
Water was dripping from the bottom of my fiver. Took the pan off the bottom so I could have a look and found a large pin hole leak by the neck of the gray tank. Pulled out the wet insulation.
Are there any products I can get to repair this myself?
Also heard about plastic welding?
Thanks for your help.
Will try to call some dealers tomorrow.....heading towards Rochester,NY
2012 Started fulltiming on February 1st
2009 Carri-Lite 36XTRM5
2008 Ford F-450 Lariat
raygreg
Seattle,WA
If I could reach the area, I would try eternabond
Artum Snowbird
Campbell River, B.C., Canada
I fixed my white tank with epoxy by tipping it toward the hole and letting it all drip out, then tipping the unit away from the hole and heating it with a heat gun until a dry towel that I was able to put inside the cracked fitting didn't come out wet. I cleaned it and buffed it up, cleaned it again with alcohol and liberally piled on the epoxy all around it and let it dry for longer than the instructions say. It worked for many years, and I didn't worry about the fitting because if it didn't work it was going to have to be removed anyway.
Another thing to try might be to put a stainless hose clamp around the neck so the epoxy has something to grip against. Put the epoxy all over the hose clamp so that it makes a good ring and holds that hole shut.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
Weldon
JB Water Weld fixed mine. It was a small leak on the bottom of tank. Over a year and still holding.
Monty-Rob
Sioux Falls, SD
I have a roll of eternabond...would that work or do I need more?
agesilaus
North Florida
Yeah JB Water Weld or some of that epoxy putty for plastics should work. Eternabond I would use if I was away from home and needed a quick fix.
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
jsr21
Alberta Canada
Don't use eternabond...use this stuff especially made for ABS.
Click here
SH
Lynden, WA
We had the tank on our previous SOB plastic welded. Cost about $100.00.
2011 Heartland Big Country 3450TS
2007.5 Chev LMM Duramax/Allison
2010 FLHTC Electra Glide Classic Red Hot Sunglo
Heartland Owners Club - Washington Chapter Leaders
yankeecamper
FUQUAY VARINA, NC, USA
Agree with jsr21, If you can get to the leak the best thing to use is Plastic-Medi. It's liquid abs plastic and it goes on with a brush. Love them Zweiglers hots and Nick Taho's. lived in Rocherter for 28 yrs
Barb and Rich, Fuquay Varina, NC
2006 Dodge Ram 3500 SLT Quad Cab
Dually 4x2
5.9-Liter HO Cummins Turbo Diesel
2010 Grand Junction 350RE 4 slides
Charlie D.
E. Texas-Orange
The gray water tanks I have seen are not ABS. ABS will be black. If ABS, lots of choices. If it is a milky colored material, it is probably polypropylene or polypropylene. That limits your choices but there are a few epoxies coming on the market that will work. Read the application table on the packages to get the right stuff.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
