RV.Net Open Roads Forum: General RVing Issues: Is extra sewer hose necessary?
 > Is extra sewer hose necessary?
Page of 5
path1
seattle
Posted: 07/29/12 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Weekend project was to get rid of all extra stuff in MH. I carry a shortie sewer hose (that we use most of time) to dump and have full length sewer hose for when we hook up. Also have spare hose or extra hose for longer run to the sewer connection. Never had to use extra hose, but my thinking was someday we'll be somewhere that requires a longer run to the connection, but hasn't happened yet, and taking up space.
Question: How many times have you needed an extra length to make connection?
(Rewarding project; got rid of spices that were 5 years old, Do I really need 6 rolls of garbage bags? Found extra flashlight batteries; now expired, extra jumper cables, 2 voltage meters, found good tire pressure gauge, and forest service map from 1986).
(To cheap to buy new)
1990 37 ft 5th wheel that hasn't moved since 1996 (our best home)
1997 33 ft trailer (winter home in much warmer climate)
2005 25 ft M/H (our "stand up B" for traveling)
Dutch_12078
Great Sacandaga Lake, NY
Posted: 07/29/12 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
I carry enough sewer hose to reach 40 feet. I've only used all of it three or four times in the past six or seven years, but I was really glad I had it when I needed it. I have a twenty foot section capped and coiled up in my spare tire, and two ten footers that are my normal use hoses that reside in the waste tank bay.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
dalmationlovers
Port Orchard, WA
Posted: 07/29/12 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
I carry about 10' of hose. If I needed longer I would not dump until I leave a place. Now we are only summer campers and for most location we don't have sewer hookups. The few times we have camped at a private campground I have not had a problem. The 1 extra hose added to your short hose should be plenty.
JMHO
Arnold
fordsooperdooty
Posted: 07/29/12 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Having a spare hose only really comes in handy twice...when you need the extra length to reach the sewer dump...and WHEN (not it!) the sewer hose splits when you are dumping yout tanks!
Ask any of us how bad that is! If you need a refresher...watch Robin Williams in the movie RV!
skipnchar
Topeka or somewhere else
Posted: 07/29/12 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Only necessary if you stay somewhere that the sewer connection is too far to reach with one hose. Dump stations seldom need more than about 10 feet of sewer hose to use them effectively unless you have a galley dump outlet and a sewer dump outlet that is widely separated (mine is that way) and you want to dump without moving the RV in between.
Artemus Gordon
Redding California
Posted: 07/29/12 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
Five times. Yes five times since April 2012 I have been forced to add sewer hose ! It's a must have in my opinion!
dupreet
High Point, NC
Posted: 07/29/12 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
Only when you don't have it with you! That being said, my spare is doing me no-good in my house's basement.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
christopherglenn
a little over an hour from Yosemite
Posted: 07/29/12 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have 3 ten footers in the white pvc tube CW sells for them under the frabe just behind the dump port. I normaly use one or two, but the campground near Disneyland requires all three.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Old-Biscuit
Across the USA
Posted: 07/30/12 12:18am Link  |  Quote  |  Print  |  Notify Moderator
One that is semi rigid that when collapsed is 4' and can be expanded to 15'. It's my main dump hose.
Two 10' ones that collapse down to 3' that I have used one or both several times over the years.
One 10' that collapses down to 3'....brand new in box.
Three of the hoses plus fittings/adapter/donut etc. all fit in the sewer dump valve compartment which has a expanded metal floor.
The new one in box fits in side compartment above sewer valve compartment.
I also carry one 25' garden hose and two 50' garden hoses for macerator duty.
Plus a 4' potable water hose & two 25' potable water hoses, water pressure regulator, two water filters and a portable water softener.
Use most of it regularly.......some occasionally....all of it at some time or other.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Golden_HVAC
Fulltime, CA, USA
Posted: 07/30/12 12:36am Link  |  Quote  |  Print  |  Notify Moderator
Yes I think I would carry the extra hose in case one breaks. And about every 5 years replace the oldest hose and keep the newer one that is still not leaking.
Fred.
Page of 5
