RV.Net Open Roads Forum: Travel Trailers: Propane Bottle Brand
 > Propane Bottle Brand
bobsrvnet
Alberta, Canada
Posted: 07/30/12 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Good day all, my RV 30lb bottles have expired their 10 year term so i'm going the route of new bottles. See pic below of a couple local places selling them. Anyone have any feedback if these are good/bad or otherwise?
Any feedback is appreciated.
WORTHINGTON Pro Grade 30lb Propane Tank, with Overfill Protection Device and Quick Connect Coupling
* This post was edited 07/30/12 10:54am by bobsrvnet *
2002 Peak Manufactured - Frontier Plainsman T27FR
2007 Toyota Tundra TRD SR5 - 5.7L iForce
camperdave
northern, California
Posted: 07/30/12 11:18am Link  |  Quote  |  Print  |  Notify Moderator
funny, I just ordered a set of those 30# bottles last night after I couldn't get my old bottles filled up this weekend...
My very limited research (amazon.com reviews) basically said it's a thinner metal than the older bottles, the base and handle bend easily, and they are often damaged in shipping. I bought them anyway.
1998 Ford E350 extended van, V-10, 3.73
1998 Fleetwood Terry 22lw, 24' long, 5000 pounds
Equalizer, Prodigy, Link-10, CPE 2000w generator
bobsrvnet
Alberta, Canada
Posted: 07/30/12 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Dave, I wonder then if all the newer bottles arer made with thinner metal etc compared to the older bottles.
Anyone else have any feedback?
HappyKayakers
Black River Falls WI
Posted: 07/30/12 11:36am Link  |  Quote  |  Print  |  Notify Moderator
While you're researching prices, have you checked a local propane dealer to get the cylinders recertified? If they're in good shape that may be your best option. Not sure about Canada but in the US there are 2 different recerts that can be done - 1 is good for 5 yrs, the other for 7.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
old guy
Oregon (pronounced Or e gun)
I hear they are making them out of fiberglass now with a window in them so you can see how much gas you have left.
ShadySkins
Douglassville, PA
Posted: 07/30/12 11:40am Link  |  Quote  |  Print  |  Notify Moderator
I haven't seen these in larger than a 20lb and they are very expensive. I have been trying to justify the cost for my Weber Grill.
2011 KZ 321BHS
Pulled by a 2007 Toyota Tundra Crewmax 5.7
Connected with a Reese Dual Cam
Stopped by a Tekonsha P3
swebber
Brunswick , MD
Posted: 07/30/12 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
We use the fiberglass 33.5 lb tanks here on our forklift. There is no window on these but they are translucent, you can see the LP sloshing around inside.
Steve Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
NJRVer
NJ
Posted: 07/30/12 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
X2.
mlts22
Austin, Texas
Posted: 07/30/12 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
From what Lite Cylinder's website gives, the biggest they go are the horizontal tanks on the forklifts. Vertical bottles, 25 pounds is as big as it gets.
camperdave
Posted: 07/30/12 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
I've also read that the composite cylinders don't directly fit in the same way as the metal tanks. If you have a mounting bracket setup or foot that the cylinder needs to fit into precisely (I do on the front of my trailer) it may be worth seeing if you can see one in person before buying to make SURE it will bolt in.
fwiw, here locally I could have had the tanks recertified for 1/2 the cost of new tanks, but decided to go new since the old tanks were rusting quite a bit, and have the older wrench style outlet instead of the newer big knob type. I need new hoses anyway, decided to just upgrade it all to the current design. As an added bonus, I could now use them on my home grill if I ever run out of gas in the middle of a BBQ.
Plus, the recert is only good for 7 years instead of the 12 of a new tank.
