RV.Net Open Roads Forum: Class A Motorhomes: Coach Batteries
Twostepen
GreenRidge , MO.
Posted: 07/30/12 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
We purchased a 97 Fleetwood Flair last year, this is out first coach.Coach batteries approx. 6 years old. Had them checked one was bad the other was weak.Replaced them with new deep cycle 6's they are hooked in series. I have power to all my coach lights when I am plugged in to shore power or when the genset is running. No power to anything when genset and shore power is unplugged. No power to coach when the engine is running either. What if anything should I be looking for.
Ivylog
Blairsville, Ga. USA
Posted: 07/30/12 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Turn your batter disconnect switch back on.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
mockturtle
WA
Posted: 07/30/12 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure about his but my generator won't turn over when the disconnect switch is on.
2000 Born Free 24RB Class C
6.8L Ford V-10 Engine, E450 Chassis
2002 Honda CR-V toad
Roadmaster Sterling A/T towbar
VIP braking system
Eddyline Merlin kayak
Twostepen
GreenRidge , MO.
Posted: 07/30/12 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
I did turn the Coach Battery disconnect on, that is what has me puzzled. Should have said that in my original post, sorry
John Wayne
Long Beach, Ca
Posted: 07/30/12 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
I'd say your batt. are not hooked into the system The lights are work off the converter when on shore or generator power. Do you have a 12 volt poss. wire setting some place by the batt.s not doing anything???
John & Carol Life members
01 31'Sea View single slide, F53 V-10
96 Toyota 4-Runner auto 4x4 (Remco, M&G brake system)
Security by Bentley
God Bless
KF6HCH
sb2bb
Northern Wi USA
Posted: 07/30/12 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
reset the invertor
2007 Travel Supreme Select
Twostepen
GreenRidge , MO.
Posted: 07/30/12 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Will look again to see if there is a wire not connected. Have checked all fuses everything looks okay. Thanks
Twostepen
GreenRidge , MO.
Posted: 07/30/12 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
There is no reset button on inverter, fuses are good. Will keep looking,thanks for all the help. See someone else is having basically the same problem have been following along on his post as well.
BarbaraOK
On The Road
Posted: 07/30/12 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
How many house batteries do you have?
Barb
Barb & Dave O'Keeffe - full-timing since 2006
Traveling catpanion Shadow (age 15)
Figment II (2002 Alpine 36 MDDS)
Mischief
(2004 Subaru Forester Toad)
FMCA - F337834, SKP #90761
Our Blog
gss036
Bellingham ,WA
Posted: 07/30/12 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
What were the old batteries? 6 volt or 12 volt?
