RV.Net Open Roads Forum: Fifth-Wheels: 5th sheel hitch
 > 5th sheel hitch
feotmo
grass valley, ca
Posted: 07/30/12 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have to remove my trailer hitch often. I am older and have back problems. I was curious how other trailer owners accomplish this task. Your help would be greatly appreciated.
feotmo
Traveler II
Minnesota
Posted: 07/30/12 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have a chain hoist in my garage. Our hitch is about 150 pounds and I take it out when we’re not RVing. We travel 4-6 months in the winter, so I just take it out when we get home and put it back in for our winter travels.
2011 Cameo 34SB3
2008 Chevy D/A, Smartair Air Springs, Trailer Saver BD3 Air Hitch, Mor/Ryde pin box, IS Suspension, Disk Brakes
Nights Camped in 2011 - 165
Nights Camped in 2012 - 142
Nights Camped in 2013 - 101
johnrbd
San Joaquin Valley
Posted: 07/30/12 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
Chain hoist setup would be great if you can installed on. If not, hire local "out of work" teen or neighbor to do it.
I have same issues you do, bad back and all. I leave mine in the truck as must as possible and work around it.
josten367
Columbia, MO
Posted: 07/30/12 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
You might do some searching because someone dicussed this before. I suggested the B&W Companion. This way you can remove it in 2 pieces total of 300 lbs. You can use an engine hoist to put it in or a tractor. Someone said that you can leave it hooked on the trailer and pull it off but I won't do that.
2012 Palomino Puma Bunkhouse 5th Wheel 295KBH
2003 Chevy Silverado 2500HD Crew Cab 4x4 Gas with Flowmasters
B&W Companion 5th Wheel
feotmo
grass valley, ca
Posted: 07/30/12 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
The chain hoist in the garage sounds convenient. I have to be able to get into my garage. It is full of stuff that I need to go through and toss. The engine hoist sounds like it might work, even if I move. I had heard of leaving it on the trailer, but figured it would be rather difficult to line-up and put back in.
Thanks for all of the suggestions.
RCMAN46
NorthWest
Posted: 07/30/12 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
A search will provide you with an hour or so of reading. I use two methods. One is an electric hoist I have in the rafters of my shop building. The second method I use if I am at a campground for an extended time or at a winter location such as Yuma I leave my hitch attached and locked to the king pin.
sirdrakejr
Las Vegas, Nevada
Posted: 07/30/12 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
I left my hitch hanging on the trailer for years while I stored it between uses. Never a problem and never a backache.
Frank
Artemus Gordon
Redding California
Posted: 07/30/12 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
I got a small four wheel garden cart at sears. It's just a couple inches shorter than hitch. Pull pin and pull unit out onto cart. Wife's idea actually. Then just pull it into garage. Lifting it to put back on is not so bad. Couple inches beats 2 or more feet!
2012 Montana 3750 Hickory Edition, 2013 Ford F450 Crew Cab 4x4 Platinum options
2012 3750 Montana
Generator Box
laknox
Arizona
Posted: 07/30/12 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
feotmo
I got an 2T engine hoist for $100 from a tool shop that was going out of business. Sold the engine stand for $25. :-) I had to lengthen the boom to be able to reach over the tailgate to the receiver pocket on my B&W Turnover Ball. I set my Companion on a furniture dolly to move it around the garage. If you PM your email address, I can send you pictures. Used to be on here, but my picture host got dumped and I've never put them back up.
Lyle
1936 John Deere Model A
Pete_k
Stantonville Tn
Posted: 07/30/12 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
Use this stand low to the ground to set it on with the hoist. That way you can roll it out of the way when not needed.
I cheat and use the loader on my Kubota M-4700 to sit mine in and out with. Just set it down on a pallet then store it in the shed.
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
 > 5th sheel hitch
