RV.Net Open Roads Forum: Class C Motorhomes: Rooftop Kitchen Vent
 > Rooftop Kitchen Vent
mikeleblanc413
Sour Lake, Texas
Posted: 07/30/12 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
RE: Winnebago 2000 Minnie Winnie
In cleaning off the roof for putting Eternabond on all seams,I removed what is a rectangular vent from the kitchen. The cover that protected the vent opening had four indentions to hold the screws and these indentions had caulking over the screw heads. The white caulk removed easily as did the screws. My question is: Is that most probably Dicor Self Leveling or some other caulk?
THANKS!!!
Mike LeBlanc, "The Digital Guy"
Professional Photographer, Retired Art Educator
Sour Lake, Texas
"Digital Guy"
Facebook
Flicker
ronfisherman
SE Michigan
Posted: 07/30/12 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the fridge vent. The screw holes on mine were filled with Dicor to stop water/dirt from collecting in holes.
Kodiak Chassis Class C Forum
Beverley&Ken
Tottenham,Ontario
Posted: 07/30/12 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
x2 ours is the same.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
mikeleblanc413
Sour Lake, Texas
Posted: 07/30/12 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
THANKS...didn't think of it being the fridge vent...the two back screws had a little rust near the top...the two front screws had none...for me who has been fight water leakage...that is good news...almost finished with Mr. Eternabond...
From input at this forum...I made the decision to buy...I've worked through the leak...knock on wood...no other real issues...now I'm going to begin reading EMD360's thread on RMP (or RPM) waxing...that's my next project.
EMD360
Tempe, AZ
Posted: 07/30/12 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced the caulk on those fridge vent screws with Dicor self leveling when I eternabonded the roof. I'm guessing you are correct that is what was used before and it is the right stuff to use from what I've read.
By the way if you want to add solar panels, the shaft from the fridge vent to the floor is often the way folks run the wires from the roof mounted panel. I've been thinking of trying that sooner or later.
Good luck on the Red Max Pro/Zep High Maintenance finishing project. I'm disappointed our front cabover has started to peel. Didn't do that the first time I used the finish. But I'll just do it again. Good to get an inch by inch cleaning in to know the rig forwards and backwards.
We're hooked!
2003 Itasca Spirit 22e
