RV.Net Open Roads Forum: Slide room motor current draw? How many amps?
 > Slide room motor current draw? How many amps?
Our Place
Southwest Ohio
Posted: 07/30/12 04:23pm Link  |  Print  |  Notify Moderator
Adding in a remote control unit for the slide room and the electric awning. My slide room moves on a DC motor actuator not hydraulic. The slide-out is direct wired to the switch with huge wires (8 ga) with no relays. The remote control unit has 2 relays in it that are 40 amp each. My concern is if these relays are enough for the slide room motor.
2008 Silverado 3500HD crew cab 4x4 SRW Duramax Allison 6 speed
2014 Cougar 327 RES "Campy"
BFL13
Victoria, BC
Posted: 07/30/12 04:48pm Link  |  Print  |  Notify Moderator
The Lippert 12ft slide on rig in sig has a spec for a 30amp fuse on the slide motor's pos wire that goes on the battery post.
I have seen up to 27amps on the Trimetric when the slide is first coming in over the hump but once up and over going across the floor amps drop off to 15ish.
Some people have slides that move easier than that though.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
time2roll
Posted: 07/30/12 04:54pm Link  |  Print  |  Notify Moderator
Mine draws 10 or 12 amps. Maybe 15 to 18 at stall.
Good excuse to get a DC clamp on ammeter [emoticon]
675w Solar pictures back up
