AO_hitech
SF Bay Area
Other than the amount dumped at one time the other major difference in gray water from an RV is that it is first kept in a holding tank. This can allow bacteria to grow if the conditions are right (water and a food supply make for good conditions). Tent campers don't keep their gray water in a holding tank first.
h2guy
Ain't seen a sign yet!
In the '60s in Hawaii (Kauai), our washing machine was on a back porch slab with the drain running under the slab and over to a banana tree. Had one boy in diapers (cloth). Soap in those days was full of phosphurs. Had the most giganticus flavorful bananas you every saw.
Rick & Carolyn
01 Ford SC 4x4 DRW
01 CarriLite 5ver
down home
south
Water pollution by small users is rampant. There are numerous springs and small streams where they let their cattle use as neccessary. The water would support trout and other wildlife but is dangerous to us.
Cattle ruin a lot streams this way. It now not legal but no one presses it generally. There are many National Forest that has several streams that flow through and cattle, on just a few acres, on private land ruin the water. It looks clean but don't stand in it with a cut on your leg.
It truly is aggrivaiting, that the head waters, of a local little river, arise, from a large spring is pristine until at the foot of the mountain a few folks let their cows and pigs ruin the stream. Down stream other contribute to what would be a very, and was 25 years ago, healthy water way.
jtrent6415
Omaha
garyhaupt wrote:
a beer in the drivers lap
That made me laugh...
2011 Keystone Passport 2910BH
2005 Ford F-250 King Ranch (yes, the dreaded 6.0)
2004 Suburban 1500
rustycopperballs
Four Corners,NM
Out here on the western slope and SW corner of Co. the hosts were recommending to us to drain the grey water from our tanks, because it's so dry out here.
HamsHog
Fulltimer/ Palm Springs, CA
If while boondocking you left your grey tank open, you wouldn't be holding the water and letting it build bacteria. With a 50 to 100' hose, I don't see any problem, other than attracting critters to a wet spot..
Regards, Hamshog
2009 Silverado 2500HD EC/SB Dmax/Alli - SuperGlide 18K - Firestone Bags - 265/75R16's -
2010 Carri-Lite 36XTRM5 w/ Big Foot - Champion 4000W
2005 Harley-Davidson Road King Classic
2005 Jeep Wrangler Unlimited LJ
2007 Fleetwood Pegasus Ultralite M-180FQ
Jerrybo66
AZ
We registered into a National Campground in Northern AZ. and the attendant said our totally full gray tank couldn't be dumped because his tanks were full. They had it hauled out. He then said it would be ok to dump it at the site. I felt guilty so I drained it in buckets and distributed it in different parts of the forest. The next day there was no sign of my dump. When we desert camp I always dump in the desert because the cactus may not see moisture for months. The amoeba brain before us dumped his black tank. We camp in an area where we may not see another camper for a week-end but even there it's possible to incur a subhuman species that would defile the desert.
The real problem, that these sub-human vacuum brains that communicate with grunts, are allowed to vote...
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
AO_hitech
SF Bay Area
I was told by a "government official" that I could dump my gray tank where I was in a soon to be regional park. I don't believe it is legal and did not dump it. However, it seems like there is a lot of confusion over this issue.
garyhaupt
Back living in Kitimat..northern BC.
If you want to worry about pollution, check out mining pollutants, fracking pollutants, chemical manufacturing pollutants..then talk about your grey water.
We are being bamboozled about the crud that is being pumped into our streams and food cycles..and told that putting some grey water on the ground is bad? cripes.
If you want a bad day..Google fracking in Pennsylvania.
Gary Haupt
I have a Blog..about stuff, some of which is RV'ing.
http://mrgwh.blogspot.ca/
AO_hitech
SF Bay Area
As long as it "dries" quickly there is nothing wrong with dumping gray water on the ground, except that it is illegal. But the laws are made by people who don't understand what the are writing laws about.
