I have a Georgia Boy built on a 2001 Ford chassie.
Can anyone tell me where to find the switch so I can use my Onan gen.
The gen is on the back left corner and the breaker box is the next compartment forward.
Tom
There is usually a remote start switch panel located inside the coach. Most are in the same area as the panel with tank lights etc. on it. Should also be a start switch on the generator itself. If you don't have an automatic transfer switch, you will have to plug the shore power cord into the generator receptacle, usually located in the same compartment as the cord.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
I'm sorry, but thanks guys, I was asking about the transferr switch.
I just got a call from the factory. He told me a metal box would be within a foot of the breaker box. He said I may have a loose ground or a bad circuit board. He said it should cost less than $100 if it's the board.
I'll go see what I can and after I make a mess I'll take it somewhere to get it fixed.
Tom
Beverley&Ken wrote: There is usually a remote start switch panel located inside the coach. Most are in the same area as the panel with tank lights etc. on it. Should also be a start switch on the generator itself. If you don't have an automatic transfer switch, you will have to plug the shore power cord into the generator receptacle, usually located in the same compartment as the cord.
Beverley and Ken
This is the same on my parents bounder.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
