RV.Net Open Roads Forum: General RVing Issues: Black water tank gauge.
 > Black water tank gauge.
Montana Marine
Montana
Posted: 07/31/12 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
We are having trouble with our black tank gauge as it seems to register 3 dots (2/3 full) even after we dump. We filled it completely full with water and drained again and it was better, but after the next dump it still read almost full. I am assuming that something is interfering with the gauge, but how can we fix it? Is this a common problem, as we had the trouble in our earlier TT as well?
pianotuna
Regina, SK, Canada
Posted: 07/31/12 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
The gauge fouls in most RV's. I more or less ignore mine now.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
mdfenley
Winder, Georgia
Posted: 07/31/12 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
X2
There are sensors which are little metal studs in the side of the tank. As you fill up the tank, the liquid and other matter touch the studs and cause you to get an indication of the level in the tank. As you are experiencing, crud don't always come off the studs. I crawled under mine to check it out and they didn't even install the sensors correctly. there is only 1 inch gap between off 4 sensors with a 5 inch gap between the top sensor and the top of the tank.
You are better off just looking down the the toilet and seeing where the level is. I have a family of 5 and we can't fill the black tank in a weeks time if that gives you any indication of how much material the tank should hold, but then again, different campers have different size tanks. You will get to know yours over time.
Good Luck.
tvman44
Southwest Louisiana
Posted: 07/31/12 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Very common problem, It would take a very through cleaning and that is a constant uphill battle.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
midnightsadie
ohio
Posted: 07/31/12 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
we put calgon in each tank, helps clean the sensors, there is a aftermarket kit I
EricGT
PA
Posted: 07/31/12 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
I put water softener and detergent in mine.
While driving down the road it will register 2/3 full just from the soap coating the tank walls.
I too have learned just to ignore mine.
2002 'The Rogue' by Mckenzie div of Monaco Coach
24' E450 chassis, V10, Class C, Single slide
K3WE
Missouri
Posted: 07/31/12 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
It's a common problem, this has happened to me once or twice- So far, my fix has been to put ~10 gal of water in our 40 gal tank and drive around with it to get some good sloshing going. Good luck- and know that you can look down the hole (and use experience) to know when things are getting full.
1rickw
redwood City, CA USA
Posted: 07/31/12 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
I completely ignore my gauges. None of them work properly. Sometimes the grey tank is OK but other times it's not. The black tank always ready at least 1/2 full. After 9 years with this MH, we kinda know when to dump. Have never had the black overflow, but the grey bubbles into the shower and I go out and dump.
2004 Jamboree 26Q + great wife to travel with
skipnchar
Topeka or somewhere else
Posted: 07/31/12 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
It is common when cleaning of the tank is insufficient to clean the sensor.
RustyFairmount
Michigan
Posted: 07/31/12 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
Looking down the toilet doesn't always work. My winnebago toilet was over the wheel well. The waste had to make a 90° turn to enter the tank. Not a good design.
