clucey
Chestermere, AB, Canada
Does anyone know where to buy the foam Heartland uses to seal plumbing pipe gabs under their trailers. Its black poly expanding foam. I see some use the Greatstuff Pond foam. Is this the same stuff expansion wise ? Any other products that can be easily sourced ?
Corkey05
Washington State
This is what I used. It's available at Home Depot too.
2008 HR Endeavor PDQ - Blazer 4 Down
FMCA F374292
joelc
Milford, PA
They probably used the "expandable" "Great Stuff" it is called you can get at Home Depot and Lowes. After application paint it black. Works great, I have used it. Wear thin latex gloves. It is a night mare getting it off your hands.
ScottG
Bothell Wa.
Yes, HD (and ACE H/W) has the black which is the maximum expanding formula.
Scott, Grace and Wesly
H0NDA eu2000i
gbopp
The Keystone State
joelc wrote: They probably used the "expandable" "Great Stuff" it is called you can get at Home Depot and Lowes. After application paint it black. Works great, I have used it. Wear thin latex gloves. It is a night mare getting it off your hands.
Definitely wear gloves when applying foam. I learned the hard way.
mchero
Concord, NH
DO NOT let it drip on anything! if you have a painted area near where your working I'd mask it off.
Robert McHenry
Concord, NH.
1993 Fleetwood 36' Pace Arrow
Cummins 8.3l Turbo 300hp (uprated)
Allison 3060 Trans
2005 Jeep Grand Cherokee
http://dieselrvowners.com/forum/index.php
MEXICOWANDERER
las peƱas, michoacan, mexico
I'm not within 500 miles where I can see this stuff, but many times black poly is UV resistant. I'd be very interested in learning about it. Regular ivory colored foam just goes all to heck when the sun hits it for long.
westend
all over
Mex, the FAQ sheet.
Yes, the landscape foam is UV durable. I've used it and it has a greater bond strength than the indoor stuff, alo somewhat more difficult to apply, it's thinner when dispensed. If used in a vertical orientation, have some tape or other backing material to hold the Landscape foam in place until set.
'03 F-250 4x4 CC
Francesca Knowles
Port Hadlock, Washington
And for mercy's sake, BELIEVE the label when it says to apply in carefully judged quantities- it really does continue to expand....and expand...and expand...until before you know it there's a gigantic bulge where no bulge was meant to be.
Never mind how I know that!
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
YC 1
Yuba City Calif.
Corkey05 wrote: This is what I used. It's available at Home Depot too.
Ditto: I found it at OSH. Excellent stuff.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
