RV.Net Open Roads Forum: Travel Trailers: Uneven tire wear
 > Uneven tire wear
campingnodak
north dakota
Posted: 08/02/12 10:23pm Link  |  Print  |  Notify Moderator
New to the rv world and this blog. Bought a used 2012 Gulfstream 2 weeks ago and took it on a 250 round trip camp and all 4 tires wore the tread off the inside and outside. The tire pressure is good, just wondering if the axels might be off? The dealership is trying to tell me its a used trailer so I'm on my own. Any input will help. Thanks
bldrbuck
one or the other
Posted: 08/02/12 10:30pm Link  |  Print  |  Notify Moderator
The type od wear that you describe is due to over loading or low pressure. Air the tires to the max.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 35' King of the Road 5er, 192 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 2 Trogan T105 Batteries, Me, my wife and 2 maltize furkids.
clearnetedm
Alberta
Posted: 08/02/12 10:47pm Link  |  Print  |  Notify Moderator
Near the bottom of this doc has some good advice on different tire wear. I think page 25.
alko
Btw what size of tire and loadrange, as well as the psi you are running at?
2013 F150 XLT 3.5EB Max Tow
2008 Ford Expy EL
2012 Rockwood 2601S
path1
Varies with weather
Posted: 08/02/12 10:50pm Link  |  Print  |  Notify Moderator
I had a trailer that one axle was put into place crooked by about 1/2 inch. But my tread wear took a lot to see that kind of wear. I just rotated tires and wear was evened out then. If you are "on your own" I would take it to an alignment place that is repected where you live. Spent some time on the phone and find a good one. I found a good one by asking at alignment shops that didn't have the overhead heigth to get my mh in where they would take it to. When 2 names poped up the same I went there and was happy with results (not the price) but results. You might have wrong springs or brackets or whatever put on by manufacture that are wrong. And could eb simple fix.
Never heard of that much wear in 250 miles something is wrong and I would trust a business that alignments are their only business more so than a RV dealer. JMO
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
Executive
Posted: 08/02/12 11:07pm Link  |  Print  |  Notify Moderator
campingnodak wrote:
= The tire pressure is good,
Have you weighed the trailer ready for camping? If not, the tire pressure may NOT be good. If the axle was crooked the wear would be across the entire tire as you would be scuffing it. Wear on inside and outside is indicative of PSI too low. Weigh your rig and then check your air pressure.....Dennis
THE WORLD IS CHANGED BY YOUR EXAMPLE, NOT BY YOUR OPINIONS
Dennis and Debi Ninth Year Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
JJBIRISH
Butler, PA, USA
Posted: 08/03/12 12:12am Link  |  Print  |  Notify Moderator
All four tires wearing on the inside and the outside is almost guaranteed to be low air pressure?
All four tires wearing that quickly means the condition causing it is serious and need immediate attention?
It is the air that carries the load not the tire? low PSI and overloading are technically the same thing? the tires carrying capacity is determined by its air volume and air pressure and its load rating is determined by it ability to hold the air volume at a given pressure?
Your dealer may have been legally correct but his attitude sucks?
Make sure the trailer has the right tires on it before doing anything (look on the tag on the left front corner of the trailer)? being a used 2012 there may be a related reason it was traded so quick?
If there was and he has hidden it from you the state AG may be of some help?
And be sure to weigh the trailer fully loaded for use before replacing the tires?
Love my mass produced, entry level, built by Lazy American Workers, Hornet
toaobigal
Chambly, Quebec, Canada
Posted: 08/03/12 05:33am Link  |  Print  |  Notify Moderator
If you bought a Visa, you're not the only one with that problem. They come with Trail America bias ply tire and they are ultra cheap tires. A good set of radials might help a lot, and curiously, radials are optional for 2013 models!
2011 Dutchmen 277RLS
amxpress
Clayton, NC
Posted: 08/03/12 05:53am Link  |  Print  |  Notify Moderator
What size tires do you have on your Gulfstream and what pressure are you running in them?
BTW, welcome to the forum.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L still in the zoo! Yeah!
abc40kids
Dale City,Virginia
Posted: 08/03/12 06:08am Link  |  Print  |  Notify Moderator
All 4 wearing exactly the same....I guess it could be the axles, but wouldn't both axles have to be in and be off the same if all 4 tires are doing the same thing. You said your tire pressure was good but that could mean same pressure all the way around but set too low (more likely)
Back to the axles, call the manufac, it's a 2012 no matter how you look at it. Friend of mine had Forest River replace both axles and all tires.... two sets wore out before they did anything and his 5er was 3 years old.
Jeff,Julie,Amber,Brandon,and Casey and Winston ( our new Golden ) and Bruno the Pug
2015 Keystone Montana Mountaineer 356TBF
2005 Chevy duramax dually 4x4 crew cab,ATX wheels with Nitto Dura Grapplers and Banks exhaust.
skipnchar
Topeka or somewhere else
Posted: 08/03/12 07:08am Link  |  Print  |  Notify Moderator
The two most COMMON reasons for uneven tire wear are overloading the axle weight and alignment issues. If you have your actual loaded weights you may be able to rule in or out, overloading but if you do not, I'd have the axle alignment checked. Poorly aligned axles is ALSO one reason for trailer sway incidents so it's more than just your tires that COULD be at risk.
Good luck / Skip
 > Uneven tire wear
