EricGT
PA
I hooked everything up last night and the macerator only spun for about a second and stopped.
I have it wired directly to the battery terminals and the batteries have a full charge.
I also left the R.V. plugged in during this to help keep the batteries peaked.
The fuse is good and nothing went through it but water.
Faulty macerator?
2002 'The Rogue' by Mckenzie div of Monaco Coach
24' E450 chassis, V10, Class C, Single slide
1995brave
San Antonio, TX
Could be. Is this a new or used macerator? If used you may have to take it apart and clean it.
dks
Mississauga
When you say the fuse is good are you talking about the one in the control handle? I've blown a few fuses, and it sounds like your fuse blew in the handle (Flojet).
tvman44
Southwest Louisiana
Did you check the 20 amp fuse in the on-off switch? Also remove the macerator and look at the impeller and see if something jammed it up.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Bert-64
Southwestern Ontario
Hair around the cutters does it with mine. I have to take it apart once a season to clean it. The wife blames me but since I have no hair I thinking must be hers.
Tell a man that there are 400 billion stars and he'll believe you. Tell him a bench has wet paint and he has to touch it.
2001 Winnebago Brave 32
1999 Jeep TJ
10' Zodiac w/ Mercury 4hp
phillyg
Front Royal, VA
Macerators (at least on boats) don't last more than a couple of years. They don't get used a lot and the impellers get stuck or wear out.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
Bobbo
Wherever I park
When that happened to me, it was the fuse in the on/off switch.
Until then I didn't even know there was a fuse in there.
Bobbo, Linda and the furry kids (1&1/2 German Shepherds)
2007 Winnebago Outlook WF331C on a Ford E450 Super Duty Chassis
2010 Subaru Forester w/BlueOx baseplate & Ready Brute Elite towbar
YC 1
Yuba City Calif.
Mine is four years old but I take it apart annually to clean. I found a piece of plastic last time that was reducing the water flow.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
Odessa Grandma
Salem, Missouri
We got one of those this year and it works great. For future reference.......how o you take it apart to clean it???
Grandma and Grandpa
Salem MO
No truck just a Cedar Creek 29 RL
nalcon
SE Texas
Depending on the brand of pump, most have a screw on the back with a rubber plug over it. You can remove the rubber cap and turn the macerator with screwdriver or a quarter to see if its jammed. You should be able to see into the inlet of the macerator and see the metal cutter.
Charlie and Sherrie
'99 Fleetwood Southwind Storm 31'
'10 Honda CRV EX-L
FMCA F417071
