RV.Net Open Roads Forum: General RVing Issues: Honda Eu2000 Generator Question
 > Honda Eu2000 Generator Question
Sillybugs2
Washington
Posted: 08/03/12 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
I do like the idea of back up power at home. I am going to get the 2000. And I spoke with my mom tonight and she told me she had just sent me $1500 for my birthday as a surprise. A huge one as I usually get $50. My dad passed away in May and she helped my brother replace a slider door in his home as an early birthday present so wanted to give me the same. So generous. And bonus, now I may be able to get the ipad I want
2010 Dutchmen Sport 27B
2001 F150 Supercab 4x4
ktmrfs
Portland, Oregon
Posted: 08/03/12 11:14pm Link  |  Quote  |  Print  |  Notify Moderator
while the honda 2000 is wonderful, and we have two, if I was buying again, I'd seriously look at the blue ones (Yamaha) they now have some very fine generators as well. when we got our first one Yamaha didn't have much to choose from. Now they do.
and seriously, I'd stay away from the honda/etc 1000. Really aren't that much less than the 2000 and in most cases won't run a microwave, and also won't be able to handle some common battery chargers.
2011 Keystone Outback 295RE
2004.5 Silverado 4x4 CC/SB Duramax/Allison
HuckleberryHunter
Issaquah, WA
Posted: 08/03/12 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
We bought a eu3000is last fall. It doubles as our RV generator (will power the AC, which we also rarely use) and as our home emergency generator. We had to use it last winter during the ice storms that took out our power for three days. Very happy to have it. I set it on the back deck, so I didn't have to run a mile of extension cords and could barely tell it was there.
I think an eu2000 would be a great alternative if I didn't want it to run the AC on the TT. The eu3000is is a beast to lift. The 2000 is much more manageable and portable.
Best luck on your decision.
dahkota
Washington, DC
Posted: 08/04/12 04:54am Link  |  Quote  |  Print  |  Notify Moderator
We used to boat-camp a lot and bought the 1000 for morning coffee, emergencies, and anything else that may have come up. It was light weight and small, fitting into a space in the cuddy very easily. We used it that first weekend and on the Monday after exchanged it for the 2000. I don't remember exactly why except it probably had problems running our 900W coffee maker. We are very happy with the 2000 now. We used it at home a few weeks ago when we lost power for four days and it was a godsend.
2008 Ford F250 diesel
2013 Keystone Sprinter 277RLS
pa traveler
usa
Posted: 08/04/12 06:41am Link  |  Quote  |  Print  |  Notify Moderator
When charging batterys with the 2000 will it still work on eco mode? I like the quietness of unit on eco mode,but was wondering if it still charges as good as full mode.
Desert Captain
Tucson
Posted: 08/04/12 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Yes.
mbopp
Henrietta, NY, USA
Posted: 08/04/12 08:24am Link  |  Quote  |  Print  |  Notify Moderator
If you're using the trailer converter or external battery charger, no problem w/ eco mode. Mine just putts along.
Should you use the 12v charging plug right off the generator, it has to run full throttle to get 8 amps (a very inefficient way to use it.)
2013 North Trail 21FBS
2012 F-150 XLT Ecoboost ("EcoBeast") scab
micpib1
California
Posted: 08/04/12 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Our rig has a built in Onan/Cummins 4000, I bought the EU2000 as it is much quieter and handled 90% of our actual use. I do start the Onan when we run our AC or if I just need a few minutes of microwave, etc. JH
Wherever I happen to park
Posted: 08/04/12 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Note, if you can find it there are two Honda 2000s. the straight EU-2000i and the EU-200i Companion.. What's the difference?
The EU-2000i has a 12 volt out put that is all but useless and a single 15/20 amp DUPLEX type outlet (2 outlets)
The companion has a single 15/20 outelt (takes just one plug, not two) and a 30 amp twist lock no 12 volt.
Both work by themselves, Should you ever get a 2nmd EU-2000i and a parallel kit, the Companion will feed the full 30 amps into the trailer.
ReneeG
Meridian, Idaho
Posted: 08/04/12 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Desert Captain wrote:
Yes.
Same here. We run it on eco-mode to recharge.
2011 Bighorn 3055RL
2011 F350 SD CC DRW 6.7L Diesel Lariat, Hensley BD3 with Ford Under-Bed Adaptor
Dave & Renee plus (Champ, Molly, and Paris in spirit), Missy, Maggie, and now Mica!
