RV.Net Open Roads Forum: Onan Marquis Gold 7000 stops running after 2 minutes
 > Onan Marquis Gold 7000 stops running after 2 minutes
pbscott3
North Carolina
Posted: 08/03/12 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
My Onan Marquis Gold 7000 (gas) starts and runs for just a few minutes and then shuts off. It is putting out AC power and all fluid levels are OK. Engine runs smooth and without warning shuts down. It goes from a minute to about 5 minutes before it shuts off? It has been serviced recently and runs smoothly when it is running. Any ideas?
2006 Gulfstream Sun Voyager 8388
* This post was edited 08/03/12 10:39pm by pbscott3 *
bldrbuck
one or the other
Posted: 08/03/12 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
Check the fuel lines for cracks inside that pull shut with flow. Tjis starves the engine.
YC 1
Yuba City Calif.
Posted: 08/04/12 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Does the switch flash when it shuts down. If so it is a code. If it was recently serviced it could be an air bubble in the radiator system causing it to overheat. If lack of fuel it might tend to die roughly versus like getting cut off.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
pbscott3
North Carolina
Posted: 08/05/12 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Ranger. If the air bubble is the issue how do I resolve?
