RV.Net Open Roads Forum: when do I turn off my OD setting?
 > when do I turn off my OD setting?
bnardini
Tehachapi, Ca.
Posted: 08/04/12 09:07am Link  |  Quote  |  Print  |  Notify Moderator
I have to agree with skipnchar. If you have a truck made in the last five or six years let the computer do all the work. It is smarter than we are anyways.
Bill & Lori Nardini finally on the road!
2008 Tundra SR5 doublecab
2009 Jayco 31 RKS G2
wmoses
Houston, Texas, USA
Posted: 08/04/12 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Don't know the rig that the OP has so answering his question for his situation is useless at this point.
In my case I leave OD on and use Tow Haul mode and the rig tows like a dream, with no strain or fuss and the tranny temps are always within spec. I figure I paid for the ECU, TCU, tranny cooler, etc. in the truck and I expect it to do its job.
Just went on a 4000 mile road trip to Canada with ambient temps while driving between 90 - 100 deg.F and have had no problems whatsoever. Highest elevation going towards the Great Smokies in Tennessee was about 1200 ft or so and worst grades were allegedly 6 or 7%. Speed was set with cruise control to the maximum of my tires (65 mph) and the truck did its thing. Occasionally passed slower moving traffic with bursts up to 75 mph. No problem. Trailer was about 3800# and with my 3.08 rear axle the truck is limited to 7000# towing. Engine revs never exceeded maybe 3500 rpm, typically cruising at 2500. Might have hit 4000 when passing.
So there is the data and the feedback from my perspective.
Regards,
Wayne
2010 Jayco Jayfeather EX-Port 17Z | Tekonsha Prodigy P3 brake controller
2010 GMC Sierra 1500 SLE 5.3L Vortec V8 6-speed with Power Pack Plus Package | Hypertech Max Energy tune
_
Terryallan
Foothills NC
Posted: 08/04/12 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
My 04 150 likes it better with the OD turned off. It actually gets better MPG, and is running cleaner, and happier. In OD, it seems to be lugging, or working awful hard to stay in OD. Out od OD the RPMs come up, the engine sings, I have way more throttle response, running in the power band. Yep, Me and the truck both are more happy running in 3rd.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
Gale Hawkins
Murray, KY
Posted: 08/04/12 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
nrg2brn wrote:
New TT. the last one was very heavy, so od off, no brainer but this one is very light, and when towing, I stuck at 2,700 rpm most of the time except for hills, when it hit the passing gear. Not a lot of weird "hunting" rpms going up and down....I know the od is not a power gear, I dont want to hurt my tranny, but Id like to stay in od if its safe, im sure it saves gas...but then again I got 10 with the overdrive on, so I guess I just like the fact that with od on the rpm's are lower, seems nicer to the engine. I dont know, im not an engineer. :-{
Dave
Dave not sure what you are driving because features seem to be different for different vehicles.
The 2003 Escalade Tow Mode not only changes shifts points but increases transmission line pressure leading to less slipping/heat which I think is a good thing. OD will not engage until you are hit 60 MPH the best I remember.
Padlin
W. Ma.
Posted: 08/05/12 05:08am Link  |  Quote  |  Print  |  Notify Moderator
Really need to tell us what you drive. My 04 GMC wanted you in 3rd, the new Ford doesn't care.
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
06 Starcraft 18SB
nrg2brn
raleigh, nc
Posted: 08/08/12 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
I drive a 2006 pathfinder. 4.0 liter. the transmission is beefy - made for the larger engine. it has a tranny cooler. On the way home, I turned od off, and kept the rpms at about 2,750, the speed right at 65, and it seemed very smooth. I think this is ok. I dont know how you guys tell the temp of the tranny, my truck does NOT have a tranny temp guage. I will call nissan, but I believe my TV is not designed for od. thanks for the input. what I DO make sure of, however, is good fluid. I noticed my tranny fluid was dark at 85k, when it says to change at 100k, I changed it anyway. we do a lot of towing, and city driving. got to keep that fluid light.
nrg2brn
raleigh, nc
Posted: 08/08/12 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
oh yeah, and we got BETTER mileage with the od off, even with slightly higher rpms/ like I said, Im no engineer, lol
Desert Captain
Tucson
Posted: 08/08/12 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Get yourself a Scan Gauge (Google them), and you will get a lot more than just transmission fluid temperature. The mileage displays can get you an additional 8/9 percent better mileage if you pay attention to them. Also a code reader and a couple of dozen other gauge/displays. About $150 on Amazon.
smkettner
Posted: 08/08/12 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
2700 is fine and better than lugging the motor or hunting on the transmission. I have run mine 3200 all day no sweat.
675 watts solar
SabreCanuck
Winnipeg
Posted: 08/08/12 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
That's pretty much your answer right there.. OD off, no worries of hurting tranny and better fuel mileage???
Seems this thread is coming to a close quickly
