RV.Net Open Roads Forum: Class C Motorhomes: rear sway bar ?
 > rear sway bar ?
jamstoyz
Chesterfield MI
Posted: 08/05/12 07:22am Link  |  Quote  |  Print  |  Notify Moderator
snowdance wrote:
I installed a sway bar on our 2000 Chevy 3500 MH. We live in a very windy area with 30-60 mph winds common. We also run lots of corners and our 2 lane roads often have no Shoulder with long drop off beside them. The sway bar made it corner better and also get rid of the lean from the wind. Just trashed the track bars that were on it as they were of no help to us where we live and run..
I got mine here.. It fit very well and was a simple install I did alone.
Click Here
Thank you snowdance. Thats the info I wanted to hear and I also ordered mine from the same place lol. They seem to have the best prices. Is your gas tank right behind the rear axle too?
2001 Gulfstream Yellowstone 29'
1999 Fleetwood Prowler TT 24' (sold)
2004 Fleetwood Gearbox Toyhauler 28' (sold)
snowdance
Yreka, Ca
Posted: 08/05/12 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Yes my fuel tank is. The bar makes a dip down to go under it.. Lots of clearance. My Chevy has the rear springs by Mor-Ryde Suspension. Designed for the load of the rig. So had no need for the track bars. So very little spring flex like the Fords that often need more leafs and track bars..
Hope you have as much improvement as I did.. I used a floor jack to help hold it as I installed it.
Snowdance
We spent most of our money traveling... Just wasted the rest..
Chevy 7.4 Vortex
2000 Jamboree 23b Rear Kitchen
http://www.flickr.com/photos/snowdance38
snowdance
Yreka, Ca
Posted: 08/05/12 08:16am Link  |  Quote  |  Print  |  Notify Moderator
OK the information I gave you on the bar was wrong. Did it a long while back and remember the bend area in the bar.. But the bar is mounted low on the rear end and the bend goes out around the rear end. It hugs the rear end so ends up forward and much below the fuel tank.. So see how memories work?? Its parked in my front yard and we are starting to load it for our next trip. So took a look after thinking about what I said before.
You will also have to turn the bolts holding the lower shocks around as I remember..
j-d
Sunny Florida USA
Posted: 08/05/12 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Used the same brand and supplier for front and rear bars on our Ford. Supplier was helpful when I called, and I was also to get the brand (Hellwig) install instructions before I decided to order.
I had an issue with rear shock bolts on either the Hellwig Sway Bar or the BlueOx Track Bar, I forget which. Install of the Sway Bar was straightforward. Even the weight of the bar wasn't a problem. I slid it under on a box and that got it high enough to attach one end to the axle. Then the other end at the axle and from there the frame ends were easy.
This isn't about the Track Bar, but I called BlueOx and they had the bar expert (actually the bar designer) call me. A couple tips from him got me on on track, so to speak.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
jamstoyz
Chesterfield MI
Posted: 08/05/12 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
Awesome info everyone. Thank you so much. I'll be sure to post the results after its installed. Happy camping Snowdance
 > rear sway bar ?
