RV.Net Open Roads Forum: tt with side slide, & front and rear slide
 > tt with side slide, & front and rear slide
lrowold
The Villages, FL
Posted: 08/04/12 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
We have had the whole gammit from motor home to 5th wheel to long tag, now we are looking for a quality unit around 25' long with a side slide and a front and rear slide.
Who makes a good unit,
We are looking for manufacturer and model #.
Thank you
Larry
clearnetedm
Alberta
Posted: 08/04/12 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
This is a pretty open question. There are just too many variables to what makes a good trailer and everyone will have an opinion that may differ from every other. I'd suggest you take a trip to your local RV shop and feel some out. I'd start with what your towing vehicle weight limits and use that as a gauge on what RV is right. After that it will be all about your family needs.
If you have an idea on different RV models post that as folks can likely relate better. As well some idea's on your towing vehicle.
2008 Ford Expy EL
2012 Rockwood 2601S
lrowold
The Villages, FL
Posted: 08/04/12 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
To be more specific
I have a GMC Duramax, 2500 HD so towing is not a problem, I have towed my 5th wheel and 34' tag with no problems.
What I want is a tag, with front and rear popouts, (preferably with solid sides) and a side slide (optional).
I can go to dealers but there are only one or two manufacturers that I know of Coleman and Keystone. I want some other options?
I would like to have the base unit without the popouts or slides to be no longer than 25'.
Most dealers do not have something like that in stock.
It is just he wife and I, and out two therapy dogs and we will be traveling for extended periods out west.
Thank you for your response.
Larry
clearnetedm
Alberta
Posted: 08/04/12 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately I can't help much as I'm in the same boat as you. We have only a forest river dealer here and I don't recall seeing any with front and rear slide options. Expect for the Roo hybrid style. Hopefully others have some options for you.
Best of luck.
anaro
Mebane, NC
I have seen ones with rear slides and side slides but not a front slide as well. The cloest thing to that you will get is a HTT.
2009 Ford F250 Lariat Crew Cab 6.4L diesel 4WD
2011 Crossroads Zinger ZT26BL
Reese Dual Cam
4 nights camped in 2013!
21 nights camped in 2012!
27 nights camped in 2011!
DrBaker
Oklahoma
Posted: 08/04/12 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
Outback has models with rear slides and side slides.
The only front slides I have seen are on 5th wheels.
2011 Chevy 2500HD CC/SB 4x4 Victory Red
2003 Crossroads Cruiser CF27RL
Champion Screamer, Reese 16k, and a Blue Status Symbol
APT
SE Michigan
Posted: 08/07/12 05:34am Link  |  Quote  |  Print  |  Notify Moderator
I have never seen a floorplan with front and rear hard slides. There are lots of hybrids out there with canvas front and rear pop-out beds and a slide in the middle. Like this Rockwood Roo 21SS:
2012 VW Passat TDI
OhhWell
Posted: 08/07/12 05:38am Link  |  Quote  |  Print  |  Notify Moderator
I think it has to do with needing enough space to get that side slide in. Since canvas just folds up, it's no problem.
2008 Keystone Sprinter 299BHSS
2003 Ram 3500 CC DRW 4x4
