kwbusby
Iowa
HELP!!! We are on the road and our generator keeps cutting out as we drive. Not sure why- nothing is popping- it keeps running but the AC and other electric items are turning off?!?!? WHY?? Any ideas on how to solve this one? Will check back in once we get to another wi-fi spot in Canada (Ontario- Niagara Falls area).
2003 Rexhall American Clipper 315
Ford V10
Toad 2008 Toyota Matrix manual on a dolly
1 Wife
2 Kids
1 Boston Terrier
1 Boxer
Jim@HiTek
Gresham, OR, USA
Go to Flight Systems and download their Trouble Shooting PDF. But you might also check your oil & coolant levels.
Would help if you mentioned the brand of genset you have.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
naturist
Lynchburg, VA
Low oil in the genny would be my first guess. They all have low oil shut-off systems, and when the oil level gets down right to the ragged edge, they'll start, run for a minute (long enough for the oil to get spread around the engine and the level at the sensor to drop), then cut off.
KD4UPL
Swoope, VA
How empty is your gas tank? The generator intake from the gas tank is usually at eh 1/4 tank level. It's to prevent your generator from draining your tank and leaving you stranded. If you're driving along with 1/4 tank the gen. may have trouble finding fuel.
Laman
I may be wrong guys but I read the OP's plight as being the gen. keeps running but the AC(air conditioner) and other electic appliances are cutting out, not the gen. motor.
1998 American Eagle 40' EVS
DW and 2 DD's
wolfe10
What do you have to do to get the appliances back running off the generator?
Reset breakers on generator reset?
Tap on ATS?
Nothing-- they just come back on their own?
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
kwbusby
Iowa
Laman has it correct. \the \genset keeps running but the AC and TV, etc stop working.
Wolfe10
I turn the gen off and then turn it back on and everything runs for a while till it does it again. Not sure what the ATS is.
wolfe10
ATS= Automatic Transfer Switch
You need to identify at what point you loose 120 VAC with the generator continuing to run. If you are safe working around 120 VAC with a voltmeter, remove the lid to the ATS. Check generator IN contacts, then the OUT contacts to the 120 VAC breaker box. That will tell you if power is reaching the ATS/going through the ATS to the breaker box.
Does this happen with light loads on the generator or only with heavy loads?
PandK
Greenville, SC
Wplfe10 is exactly correct, as usual. Let us know first if your comfortable working around electricity if the answer is yes you need to find out where the voltage is being lost per Wolfe10.
Paul and Karla
Cinnamon & Pequeno - Spoiled Rotten Chihauhuas
2004 Rexhall Rexair DP3955
2013 Chevy Traverse
kwbusby
Iowa
Electricity confuses me for some reason- so no I won't be comfortable working with it.
