MTPockets1
Can any harm come from allowing a grey water tank fill completely? I'm curious to know how much more I can let drain into grey water tank after the red full light comes on... If I let the tank fill until water stands in the shower (the lowest drain), will water leak out anywhere else?
2012 3055RL Big Horn - Dexter 7000 lb axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
hallock5
Most of us have malfunctioning level indicators. When the water reaches the shower basin or enters the sink (we have two greys), those are our signals that is time to release the valve.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
SidKaye
Mt Dora Florida, Montreal QC for the Summer
No, but it may stink when it rises into the shower pan.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, ClearSpot 4G+,
http://www.kayepics.com
Greyghost
On The Road To Somewhere
hallock5 stated it perfectly.
Pat & Roger Fisher
2004 Mountain Aire 3501
2007 Honda CRV EX-L 4WD,
Jewel and Clifford Bouvier Des Flandres
Old-Biscuit
Across the USA
Depends on what method was used to install/seal vent line.....some are glued fittings, some are slip fit seals.
Is your underbelly enclosed?
If it leaks out vent line where it goes into tank then you will have grey water inside underbelly and any insulation present.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
bldrbuck
one or the other
Buy one of the blue tanks and partically dump your gray water. Letting it back-up in the shower is not a good idea
Beaker
Brevard, NC
I was curious exactly how much my black tank held and recently measured and dumped water in it. When the full light came on I had 29 gals in it. Got a total of just over 40 when I could see it in the pipe of toilet.
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
skipnchar
Topeka or somewhere else
There SHOULD be no leak but there are dozens of posts on this forum of people who find that their connection between tub and gray water waste tank is not a good one and they FIND it leaks when over filled. Just use some caution when it gets that full. After using the trailer for la while you will get a "feel for it" and based on your own use you'll KNOW when the tank is full or GETTING full.
Good luck / Skip
mr. ed
Madison, SD (but usually elsewhere)
I leave my grey water dump valve open all the time while hooked up. Occasionally I'll let it fill about halfway and then dump to clear out any solids that may have accumulated (I use a screen in my kitchen sink to catch most solids).
Some years ago I forgot the grey dump valve was closed and didn't check things until I saw liquid flowing from the underbelly. After that incident I never let my two grey water holding tanks get anywhere near full. One exception is the third holding tank (black water) which I allow to fill more than halfway in order to facilitate dumping solid waste more efficiently.
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
Aridon
SE Florida
I wouldn't say its the best practice but if it happens every so often it shouldn't harm anything. Usually the tank will over flow to the shower or the sink. You'll know because it will stink unless you never cook in your rv.
2008 Newmar 4330 (Modified)
