RV.Net Open Roads Forum: EU2000i Carburator Drain Screw // Drain Fuel Pump
 > EU2000i Carburator Drain Screw // Drain Fuel Pump
mejones53
South Florida
Posted: 08/05/12 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Yamaha EF3000 which is my go to generator for most everything. Because it weighs as much as I do, five years ago I bought a Honda EU2000i for those occasions when I'm certain my power requirements will be under 2000 watts.
The Honda gets used about twice a year. Recently it got so it would not start. Had it serviced and was told the carburator needed to be cleaned. The advise I got from the shop was to run it dry every time I use it.
My question is for those who use your Honda less than every two or three months, say 2 or 3 times a year:
- Do you use the Carburetor Drain Screw?
- Do you drain the Fuel Pump in accordance with the instruction manual?
- Do you ever turn the generator upside down to empty remaining fuel in the tank?
- Have you heard about the Spark Plug Cut Off Wire from the Engine Switch and have you tried disabling that?
Thanks -
2007 Toyota Tundra DC 4x4
2008 Keystone VR1
coolbreeze01
Redding, Ca
Posted: 08/05/12 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
I just put my EU2000 away for awhile. I tipped it and drained the gas plus drained the carburetor. Has worked for me a couple years now. I haven't messed with the spark-plug.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
mbopp
Henrietta, NY, USA
Posted: 08/05/12 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
I siphon the gas out of the tank, then run it until it quits.
This spring it had some surging under load. I put some Gumout in the tank, ran it under load for 15 minutes (1500 watt heater), and the problem cleared.
I don't know what the fuel pump or spark plug cut off wire are.
2013 North Trail 21FBS
2012 F-150 XLT Ecoboost ("EcoBeast") scab
2oldman
Winchester WA
Posted: 08/05/12 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks -
yes, no, no, no. Drain tank, add a bit of Stabil, drain carb.
JayGee
Foothills of the Smokies
Posted: 08/05/12 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
I guess I've been lucky. I have never drained it, I have never ran it dry for storage, and it has always started after about 5 years of ownership. I do start it up every 30 days or so and let it run awhile. I also use Stabil in all the fuel that I put in it. It does surge sometimes for a few minutes but it always clears up after I run it full speed for a few minutes.
JayGee
2005 Winnebago Sightseer 29R
Workhorse P32 chassis
Craig A
Tampa Bay Area, FL
Posted: 08/05/12 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
I just got my EU2000i. It had 3 hours on it in 3 years, but had not been run. Had to have the carb cleaned. Now, I add about 1/2 cup of fuel in it every 30 days and run it dry. Thanks to gasahol, evaporation is much worse and anything I have with gas in it gets run every 30 days. In the trimmer, blower, and hedgeclippers, I run them, shut 'em off, drain the gas, and run them dry. No more $100 bills for me.
Beautiful wife of 33 years
26 year old son and DIL
Female Yellow Labrador Retriever Puppy
10 year old Amazon Parrot
2002 F250 4 door, 8 foot bed, 7.3 PSD with Hypertech software, timbrens, 3.73 rear axle
2006 Montana Mountaineer 344RET
2oldman
Winchester WA
Posted: 08/05/12 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
Craig A wrote:
It had 3 hours on it in 3 years, but had not been run. Now, I add about 1/2 cup of fuel in it every 30 days and run it dry.
I'll bite.. how does it get 3 hours on it and not be run?
I don't get what running it dry every month does.
mejones53
South Florida
Posted: 08/05/12 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
I'm guessing that by running it every month your are washing out whatever residue may be in the carburetor and putting a "fresh" coat of fuel on it... a way of keeping things from getting too stale in the fuel line and carburetor.
Thank you all for the responses and ideas.
I will use the Drain Screw from now on and I will run it dry with some Stabii in it. See how that works.
My doctor has diagnosed me as having a serious case of bad luck, hopefully the generator won't catch it.
Airstreamer67
Pineville, LA USA
Posted: 08/05/12 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
What it does is remove the fuel that could otherwise gum up the works...the OP's original problem.
I've had the same problem and now run the tank dry and use the carb drain screw to get the last few drops out. When the generator is needed, it takes little time to put in fresh gas and get it going.
dclark1946
Richardson,TX,USA
Posted: 08/05/12 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
I follow the same procedure but add one more step after draining the carb I start the generator and it will usually run for a second or two. I repeat this until it will not start any more.
Dick
Dick & Karen
Richardson,TX
2007 KZ Spree 240RBS
03 Tahoe/09 F250 V10
