RV.Net Open Roads Forum: General RVing Issues: Dometic Portable Refrigerators
 > Dometic Portable Refrigerators
cltkids
Lake Park, North Carolina
Posted: 08/05/12 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
We have the standard 6.x CF refrigerator in our MH and when we go on longer trips there is never enough space in the freezer or fridge. We already have 2 powered igloo coolers (igloo) that hold milk and other cold items.
We were thinking of buying a Dometic portable freezer (Portable fridge).
Has anyone every used one? Or know someone who has? I know they are really expensive ($900) but I could spend $1200+ on a new 9 cf fridge, or buy one of these..
Thoughts?
2007 Four Winds Hurricane 34B
2007 CR-V w/ Blue Ox Aventa LX/Even Brake
2 Kids/2 Dogs
robsouth
Near Atlanta, GA
Posted: 08/05/12 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking take along less and pick up what you need along the trip. We rarely fill the freezer much less the fridge and just shop where convenient during travels. Cheaper way out.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
mlts22
Austin, Texas
Posted: 08/05/12 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
It depends if you are running out of freezer or fridge space.
Freezer space, I'd look at an additional Dometic model such as what is mentioned.
Fridge space, it might be cheaper to go with a heavily insulated cooler, load a few gel packs in the freezer, and swap those in the cooler. It is repetitive, but it is inexpensive.
skipnchar
Topeka or somewhere else
Posted: 08/05/12 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Where do you go that has no grocery stores?
cltkids
Posted: 08/05/12 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
Well, we tend to pre-cook a lot of meals and freeze them...so our freezer is often jammed on long trips...which can be 3 - 5 weeks long.
I was just wondering if anyone had tried the portable freezers. It looks like there are other brands besides Dometic that make them and they seem to get good reviews.
Thanks.
Black Sunshine
Lincoln, Ne.
Posted: 08/06/12 08:12am Link  |  Quote  |  Print  |  Notify Moderator
www.compactappliance.com
Wherever I happen to park
Posted: 08/06/12 08:13am Link  |  Quote  |  Print  |  Notify Moderator
I do not have a Dometic, but I do have an Engel, Much like the Dometic (mostly cosmetic differneces, like my lid opens from the end instead of the side) and I am very pleased with it, Mine is 7 years old and the ice cream is frozen, The inside temp as measured is ZERO at the moment. I do need to clean it though as it warms a bit (say 10 degrees) if it gets too hot.
But after 7 years.. You'd need cleaning too.
It does cool a bit slower than a standard home type freezer but this power sucker only sips a mear 36 watts (3 amps at 12 volts) I don't even bother with the 120 volt cord (though I have a few lying about)
Very happy with it. Very very happy with it.
CT_WANDERER
E. Lyme, CT
Posted: 08/06/12 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I have the larger 12volt/120volt Dometic ref/freezer unit. I am very happy with it. We use it as a freezer. You just program the temperature you want it to hold. I like to travel with full supplies. We have gone some places that was not to near stores. Thought we would only be there a few days and ended up a lot longer. It is great not having to worry about our food supplies
jetboater454
Camping or home
Posted: 08/06/12 09:32am Link  |  Quote  |  Print  |  Notify Moderator
A small upright freezer can be used in place of an end table.You can get them for under $200.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
Rolling Condo
South Carolina
Posted: 08/06/12 10:40am Link  |  Quote  |  Print  |  Notify Moderator
I have both an Engel 36 qt. and an Edgestar 43 qt. from Compact Appliance. I primariarly use them as freezers. They both work great.
'90 GMC R2500 7.4L w/ Gear Vendor OD
'90 Avion 34V
Cummins Onan P4300ie
Pro Pride 3P
Prodigy
