reddfox77
ohio
1993 Georgie Boy...has oxidation and I want to put some thing on it. Any suggestions? The front and rear is fiberglass sides are made of who knows what. tahnks
sch911
Rochester Hills, MI
Do yourself a favor and search the forums for Red Max Pro. It's magic for older rigs.
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
reddfox77
ohio
sch911 wrote: Do yourself a favor and search the forums for Red Max Pro. It's magic for older rigs.
Ok thank you but what is the sides made of?
hershey
Albuquerque,(fulltime) NM, USA
reddfox77 wrote: sch911 wrote: Do yourself a favor and search the forums for Red Max Pro. It's magic for older rigs.
If it isn't metal (you should be able to determine that) than its a 90% chance that its fiberglass/gelcoat. The Red Max Pro or Zep application will amaze you.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
brirene
midwest
X2 to each of the posts above.
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
soling2003
Federal Way, WA
polish and Rejex it!
DW and 2 dogs
2011 Ford F350 Dually LB 4x4 CC 6.7 diesel
2007 Grand Junction 35TMS
Peterson 37(just sold) T-37 R/C Sailboat at home
reddfox77
ohio
soling2003 wrote: polish and Rejex it!
What is rejex?
reddfox77
ohio
I am no way putting floor wax on this thing. I know what it does over time. thinking about using meguairs D151....Any one ever use that?
C-Leigh Racing
Nashville NC
Along in the 93 GBM years, if I'm correct, I believe a GBM was a Fleetwood product, & most of those had outer gelcoat fiberglass walls.
The end caps, could be made the same way or could be a formed type of gelcoated plastic.
Look real close at the wall & end caps & see if you can see any strands of fiberglass in them. Even though the out sides will be smooth, fiberglass still has a different look to it than metal or plastic.
What ever you do, wax, Red Max or Zep, dont put anything on it until you have cleaned it perfect, to get all the dead stuff off down to the rich colors that were there when new.
Neil
rgatijnet1
I would use a clay bar, either medium or fine, to clean off bugs, debris, and oxidation. Once that is done, and the surface is as smooth as glass, which it will be, then any of the fine automotive waxes on the market will work. Clay bars are available at any large automotive supply store, or online from places like Griots, etc.
