Rodnegg
Kansas
We are looking at buying a toy hauler so our son who is in a wheelchair can get in the camper. I am wondering about the side ramp toy haulers? What do you all with toy haulers think, is any of this feasible. We currently have a travel trailer but have not used it in a while since he is no longer able to get inside it.
Thanks for any input.
Carol
~Carol
Red,
Southwest
Fantastic solution . . .
Red, *<(:{)-
Y-Guy
Tri-Cities, WA
They are pretty steep for most side loads, however I can see one being modified too. The Outback has a side load that maybe lower then some other units, it's called the Kargaroo, but my concern there is the halls are pretty narrow.
edited 08/05/12 11:01pm by Y-Guy *
Our RV: '07 Winnebago Sightseer 35J
Our Toys: Four Winns Horizon 190, Polaris Sportsman 500's & Honda Recon's
karlba
crockett,tx
our 297se while not a side ramp does have a 36in door from the garage, as stated above one issue will be access once inside, look for a unit with a rear toilet as getting up into a fron one is prob going to be difficult.
allcool
sFL Glamis PHX
I have a friend that is a paraplegic. He comes out to Glamis with us many times a season. He rides/owns a Polaris quad and a small 2 seater sand car, and has a 28' TH.
His toy hauler has a 12v electric elevator ramp on the regularly normal side door. I think the side door was modified because it is wider than normal.It all folds up inside when he's done and loaded up. We usually put out sheets of plywood once he's out in his wheel chair so he can get around camp in the sand. His pick up truck also has a cherry picker hoist type thing that he uses to get his wheel chair in the bed.
His quad is set up with ski binding type things and ski boots. He doesn't buckle down the boots, just slips in them and leaves them open just to locate his feet since he can't move his legs at all. Its a cvt so no foot work is needed. He keeps right up to us, and we fly thru the dunes.
His sandcar is set up with all hand controls. He keeps right up to us, and we fly thru the dunes.
He won't even let us help him more or less with anything. He's very independent and capable.
Where there is a will, there is a way...
Let me know if you want to talk to him about his TH elevator ramp setup, and I'll see if he will let me give you his number...
2007 WW FSW3200
RZRS k&t Turbo
2 LT500
1 Lt500 hybrid
r1Mk
Modesto
Dune sport will custom build one. They did for a friend of mine. The bathroom and bedroom are also an issue on normal TH's.
'06 GMC 2500HD D/A 4X4
'12 Fuzion 302
Winter Arctic Cat 900 1M, Polaris 700 RMK, Polaris 550 RMK
Summer Honda 300 EX, Yamaha 80, Polaris 50
ng2951
Louisiana, USA
I would check the angle of the ramp. We had the same thought for our live-in mother-in-law.
When I did a test with her powered wheel chair, I found it could not negotiate the ramp; it was too steep. I am sure I could figure out something but its not going to work by merely lowering the ramp.
Some THs are much closer to the ground so the angle on their ramps are not as steep. There are ways to make it work and no doubt a TH with a garage would be a plus...
Foard County News & Sassy Schoolmarm
with Lady & Chloe
2012 Unleashed 27SBU
2013 10 days camping
2012 50 days camping
'07 GMC Sierra 2500HD Classic 4x4 LBZ Duramax Diesel
Honda 2000sThe Bayou Bounty Hunters Cowboy Club
The Single Action Shooting Society
jetboater454
Camping or home
Maybe block up the door ramp to a decent angle,and use those wider loading ramps like the ones to load stuff in a pick up.You could pin it to the door so they don't slip.Cover it with wood and if needed I would think you could devise a removable handrail.
Good luck.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
Rodnegg
Kansas
Thank you all so much for your input and suggestions!
tonyandkaren
pennsylvania
We've looked at toyhaulers at dealers and the slope is much too steep to be safe. You might do better buying a used RV that has been converted to make it accessible. Try looking here - http://www.rvproperty.com/handicap_rv_sales_1.htm
If you want to buy new Winnebago will modify to suit your needs - http://www.winnebagoind.com/products/commercial/ability/
So will Born Free - http://dodgenmobiletech.com/mobility-rvs
Newmar makes one too - http://www.newmarcorp.com/news/newmar_desiagns_wheelchair
We've been fulltiming for about 19 years , most of the time I've been in a wheelchair. Check our blog for more information about my experiences living , camping and sightseeing as a wheelchair RVer. Good luck with your search!
Our Fulltiming Blog
Clickable Attractions Maps
4x4 Custom Class C on F450 chassis
