RV.Net Open Roads Forum: Hybrid Travel Trailers: Chev TrailBlazer SS V8
Open Roads Forum  >  Hybrid Travel Trailers
 > Chev TrailBlazer SS V8
1kennyOG
Canada
Posted: 08/07/12 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Any of you here towing a 21(ish) foot HTT with the 6.0V8 chevy?
thanks I'm looking at one to haul a 4000Lb camper
2007 Dutchman Kodiak 214 HTT
PAThwacker
East Stroudsburg, PA
Posted: 08/07/12 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
You may have the power but dont have too much payload. Our 5.3 tb has 1300lbs payload. What is the 4000lb number? Dry or GVW? The max i would tow with ours was 4500lbs without exceeding gvw and gcwr of the tb.
2008 Starcraft Travelstar Sport 21RBH
2008 Chevy Trailblazer V8 3.42/ 2004 k2500 Suburban LT 6.0, 3.73, g80 locker, center buckets, and sunroof.
Me, DW, dd08, dd12, 88lb black lab!
jdscala
Canada
Posted: 08/07/12 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
Don't have any experience with the SS. As already mentioned, your issue will be your payload. I used to tow with my 2004 EXT with the 5.3. It had lots of "towing capacity". But with a loaded trailer weighing 4200lbs, my Trailblazer's axle ratings were pretty at their limit.
2009 Max Sport 23bh
2005 Silverado 2500hd Duramax/Allison
1kennyOG
Canada
Posted: 08/07/12 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
If I get the TB it is to replace a V6 Chev Astro van that has givem me no problems towing the last 5 years on very busy highways. The TB is longer with a longer WB and double the HP.
PAThwacker
Posted: 08/07/12 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
The ss is still a swb tb like my 2008 5.3 dod version. Glorified soccer mom mobile getting swamped by 600lb tongue wt, 100 hitch, leaves only 500 for passengers and gear. We were at 10k combined with a pup. Pup required gear to be packed in the tb, dog, kid, dw, and zero payload available,
1kennyOG
Canada
Posted: 08/07/12 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
My family of 4 weighs in at 400 Lbs so not much left for gear eh? lol.
PAThwacker
Posted: 08/08/12 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Yup, you have all the power in the world with the 6.0 tb ss but severe limitations to deal with. Heck i recall an issue on trailvoy regarding hitch/exhaust issues. Thinking back it was similar to the srt8 grand cherokee too! Performance SuV, not towing suv.
khjulberg
Minnesota
Posted: 08/08/12 09:18am Link  |  Quote  |  Print  |  Notify Moderator
We've towed a Jayco 19H with a Trailblazer, overall bad idea. The TB really had no redeeming qualities over a truck (hindsight of course) The gas mileage even while not towing was worse than our Silverado. The other issue was that the vehicle wasn't really wide enough for towing...visibility was a major concern. We eventually bought McKesh mirrors which worked but even 'normal' towing mirrors don't fit the trailblazer. (I'm not going to address the ability to keep a constant speed while towing, weight issues etc). The gas mileage while I did my normal soccer mom duties was horrible (getting out of the 13 range was a problem) in the end, upgrading to a truck our mileage is better, and it tows much nicer.
go wild
Minneapolis, MN
Posted: 08/08/12 09:39am Link  |  Quote  |  Print  |  Notify Moderator
I looked at the Trailblazer SS when I was researching tow vehicles last fall. The motor is awesome, but I recall lots of comments on the Traillazer forums about how the suspension and transmission aren't designed for towing.
2007 Jeep Commander 4X4 HEMI
2010 Jayco 17Z
mbopp
Henrietta, NY, USA
Posted: 08/08/12 10:51am Link  |  Quote  |  Print  |  Notify Moderator
TB suspensions are pretty soft for towing.
What transmission does it have? I smoked my Envoy's 4L60E at 62,000 miles and that was with an aux cooler added. Trashed a fuel pump (stranded on the Interstate with the TT), cat converter, and exhaust manifold (which turned into a new cylinder head) at 78,000 miles also. GM paid for the cat, I ate everything else.
And yes you're going to run out of payload pretty quickly.
I too ended up with a set of McKesh mirrors on the Envoy. There were no strap-on extensions that worked worth a darn.
The new tv is in my sig.
2013 North Trail 21FBS
2012 F-150 XLT Ecoboost ("EcoBeast") scab
