RV.Net Open Roads Forum: Truck Campers: problems "mating" camper to truck
 > problems "mating" camper to truck
dadwolf2
Henderson,NV
Posted: 08/07/12 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
I know the distance between my jack feet and my tires from when I first offloaded my TC (or any other time I've offloaded, it's always the same). Now, you can use lots of different things; tape, paint, rope, something long and straight and make a straight line out 10-20 ft out in front of the TC. I just use my drivers side mirror and put the outside of the tires on the line and slowly drive back. No neck twisting involved. Starting out 10-20' and knowing the correct lineup way in advance really helps.
2005 Dodge Ram 2500 CTD,4X4,NV5600,Pullrite superglide
2005 Skyline Rampage 289
2011 Outfitter Apex 8 (Love it)
mountainkowboy
Socal High Desert
Posted: 08/07/12 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
This is my loading system, these along with the mirrors, usually loads the first time.
* This post was edited 08/15/12 09:38am by an administrator/moderator *
Chuck & Ruth with 4-legged Dixie & Hanna
90 F350 S/C Dually, Camper Pkg, 460/ZF 5spd, Banks Powerpack, Torklift Superhitch/32" extension.
90 S&S 11 SCB
94 Alpenlite 29RK DL
06 CRV
64 IH Scout 80
Boatycall
Tacoma, WA
Posted: 08/07/12 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Play the shot game! Every time you load and miss, you have to take a shot.
After a few tries you won't care if it's not on perfect.
After a few more it'll look perfect, regardless how it's loaded.
Here's what happened last time I tried that method.....
* This post was edited 08/07/12 08:11pm by Boatycall *
01 F350 DRW 4x4,Torklifts,SuperHitch,F550 Rear Suspension,Roadmaster ANTI-Sway Bar,Rancho 9000s
2012 AF 1150-4 Trojans,1.5kw Inverter,32" LCD,19" LCD,Basboard heat,Dish Tailgator,Ice maker,3 awnings,80a charge circuit,Polk Audio/Kenwood/Kicker sound system
jimh425
Western WA
Posted: 08/07/12 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
I just added the D.U.H system last weekend. I wish I had done it sooner. It's much easier than tape down the center.
'06 F350 Lariat Supercab SRW, 6.0 PSD 4x4 Long Bed, Intake Elbow, Walker Big Truck Muffler. '06 Host Rainer 950 Double Slide, Fastguns. Firestone Air Bags, Rancho 9000s, Vision 19.5s with Hankook DH-01 245s, Energy Suspension bump stops.
whizbang
Kenmore, WA
Posted: 08/07/12 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
Hop out and take a look. Seriously, when you're 1/3 of the way in, jump out, run back and see if it's lined up. Keep jumping in and out of the truck and checking your work. Eventually you will get it right on and you will develop an idea of what that looks like from the drivers seat.
Whizbang
2010 F150 with 1994 Jayco Sportster 7ft Pop-up
http://www.raincityhome.com/RAWH/index.htm
mbeggs
Grants Pass, OREGON
Posted: 08/08/12 09:07am Link  |  Quote  |  Print  |  Notify Moderator
THANKS FOR ALL YOUR REPLYS!. I was checking off and on all day yesterday and was pleasantly surprised with all of the help and ideas that were posted. Again, Thank you to all. One question though....how did that one guys get that camper in backwards??? I thought I was having issues :~)
~mike
daveshan
Durango Colrado
Posted: 08/08/12 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Hang around a bit, some of our members are PhotoShop wizards
'99 Alpine 36SDS/8.3 ISC 330 Cummins
Or
'05 Lance 845
'06 Super duty SC/SB 6.0
Upgrades include: StabilLoads, Air Bags & Timbrens,Swaybars
Usually towing an '01 Wrangler, lifted/locked on 35"s or a mildly built '98 Cherokee on 33"s (only one locker)
RichandLiz
Connecticut
Posted: 08/14/12 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
**Just another method - that works for me**
I measured out from the center of my truck bed to the rails and the center of my TC to the overhangs. Placed a piece of tape. Back under and have the tape follow the bed rail of the truck. Focus on one side, monitor the other side - both in the mirror. Keeps it straight. Rear of TC (where it juts out) has about 3/4 inch space when reaches the rear tailgate area of the truck. I have it marked front, middle, and rear. For the middle of the TC wing, I measured off the outside of the TC for the front and rear.
*Reason for the wood along the base of the TC is that my TC is for a mini truck and I have 44" between the wells. A 1/4 inch wedge keeps it centered which I drop in as I lower it.
May give you another idea. Combine all..or some... to make it work for you.
mkirsch
Rochester, NY
Posted: 08/15/12 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Maybe this won't work for heavier campers, but my camper will "wobble" about two inches in every direction when it's standing on the jacks if you push on it hard enough.
All I have to do is get the camper close, then I can fine tune it as I lower it into the truck bed.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
James'
Ventura, CA
Posted: 08/15/12 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
LMAO!!!
2006 Chevrolet 3500 HD 4X4 dually, crew cab.
6.6 diesel, Allison trans. Air bags.
2011 Lance 992 duel pop-out, 2200 gen, 135 watt solar panal, Yakima skybox.
