RV.Net Open Roads Forum: Towing: Trailer saver DB3 ajustment
Search only in Towing
Open Roads Forum  >  Towing
 > Trailer saver DB3 ajustment
vgstef
Canada
Posted: 08/07/12 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
I like to know if i need to adjust the height of the hitch (trailer saver BD3) to get proper clearence how can i do it ( i did have the air bag inflate to the max but still need to go up to get 6 inch clearance.
Thank you
eric
ljr
Pennsylvania
Posted: 08/07/12 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Mine has bolts in each side with multiple holes. Doesn't yours?
Larry
wild bill
Mira Loma, Ca. USA
Posted: 08/07/12 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
TrailerSaver makes a base mount that can change the height of the unit...the air bags should be inflated so that the air bags are half way between full up and full down....while the trailer is attached...
05 Dodge 3500 Q-Cab,GearVendor 8 Sp,PacBrake,Banks intercooler & intake,TST R49,Transferflow 70 tank,TrailerSaver Hitch,05 Raptor 3612,Second AC, solar 6 battery sys Xantrex 3000, WEB SITE
http://home.earthlink.net/~wbrown02/wildbillwashere22/index.html
vgstef
Canada
Posted: 08/07/12 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Yes i do have the multiples holes but i was not sure if i could adjusted using those holes.
vgstef
Canada
Posted: 08/07/12 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have any pictures of the base mount from trailer saver ? Can i use the extra hole on the side to made adjustment ?
wirenutz
kent,Wa
Posted: 03/19/13 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
how much can one expect to pay for the trailer saver DB3 ?
