RV.Net Open Roads Forum: Class A Motorhomes: What Size Inverter for Residental refrigerator?
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > What Size Inverter for Residental refrigerator?
Gator48
Branford
Posted: 08/08/12 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
I was thinking about 2000-2500 watts, and a 4 battery stackIF the house batteries ran down too quick.
We don't dry camp so it's just for daily drive time when we choose not to run the generator.
this is still very much in the planning stages.
Thanks all
Jim@HiTek
Gresham, OR, USA
Posted: 08/08/12 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Some refers, like Samsung, run perfectly well on MSW inverters. And it doesn't affect the warranty.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
mena661
Posted: 08/08/12 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all
This will work well.
Trojan L16 6V's 740 Amp-hours
jeepbluetj
California
Posted: 08/08/12 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
These inverters may sound really big, but they really are just to handle the startup current. The run power is typically around 100w or so.
I've tested a small fridge on a 600W inverter and it ran fine - but you couldn't use it for anything else (like running a coffeemaker)
If you're only using it while driving, most of the power will come from the alternator.
tallyo
Fort Myers,Florida
Posted: 08/08/12 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2000 watt inverter with 100 amp converter/ 6 house batteries. Our frig is a 2door kitchen aid with bottom freezer.
Tallyo
2012 Phaeton 40 QBH
Freightliner, 6 spd Allison
2010 Chevy Equinox 2LT w/ Brake Buddy Vantage
Drinks-6, Eats-4, Sleeps-2
Semper Fi
Gator48
Branford
Posted: 08/08/12 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Ok I thought of another question.
Is it better to put the inverter close to the batteries and run the 120V to the fridge? Or longer battery cables and plug directly into the inverter?
Jim@HiTek
Gresham, OR, USA
Posted: 08/08/12 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely better to put it close to the batteries.
mena661
Posted: 08/08/12 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
X2, you can go a LOT longer on AC wiring without a significant voltage drop than DC wiring.
PenMan
New Mexico
Posted: 08/08/12 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Rich D. wrote:
Mine came with a dedicated 1500 watt PSW which connects to the same battery banks as the other inverter(s). Reason it is slightly larger is that it powers the electronics as well as the 22 cu.ft. KitchenAid SxS refrigerator. PSW inverters will also reduce the power consumption for the refrigerator as the compressors do not like MSW power and current draws on MSW are higher.
PENMAN, no the OP is not kidding. New highly efficient refrigerators are easily run from the coach barrery bank for considerable lengths of time without generator or shore power.
Thanks for the info. I was trying to imagine how many batteries would be needed to run a house frig for any length of time. Now I have a better idea.
Chris and Jane and two boys (and a DDIL) who prefer tents
2013 Open Range Journeyer JT337RLS
2006 Dodge Ram 3500, 4x4, Crew Cab, DRW, 5.9 turbo diesel
1996 Harley Davidson Electraglide
MrWizard
Traveling
Posted: 08/08/12 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
we have been running an 8cuft apt size residential fridge on a 1200w Tripp-lite MSW inverter for 21 months, this is 24/7, nothing has been off unless i was working with the battery cables,
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
