RV.Net Open Roads Forum: Tech Issues: Distorted Battery Disconnect Switch
 > Distorted Battery Disconnect Switch
tkcas01
Roaming Fulltimer
Posted: 08/11/12 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Follow-up Report from OP
Got the switch off and sure enough it must have gotten very HOT! Kinda scary - who would have thought a battery disconnect switch could almost burn your rig down! Here are some pix.
My last known location (is here)
    MEXICOWANDERER
    las peƱas, michoacan, mexico
    Posted: 08/11/12 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
    Bad design. Too small a switch. Your new switch will eliminate the problem. Your old one was like putting a 175X13" tire on an F-350
    Rvpapa
    Alberta , Can.
    Posted: 08/11/12 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
    Safer to choose a good one in the beginning.
    Art.
    tkcas01
    Roaming Fulltimer
    Posted: 08/14/12 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
    Another OP Update
    On further thought, I agreed the original switch was just not heavy enough, even though I had already ordered an exact replacement. I found a heavier one here:
    http://www.pplmotorhomes.com/parts/rv-co........er-switch-contour-heavy-duty-55-3765.htm
    Here are a couple of pictures contrasting the two switches - the larger one is MUCH heavier.
    smkettner
    Posted: 08/14/12 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
    What is the amp rating of each? What is the combined fuse rating?
    675 watts solar
